CCTVHK Posted February 7, 2009 Posted February 7, 2009 DVBViewer has been nice and it would be great if the mouse wheel can control the zoom function (more than resize but enlarge the picture beyond the full screen limit) and the jump forward/backward function during playback. Similar functions are available in the zoom player, which also allows the enlarged picture be moved by holding the left click, so the viewer can see a particular portion. Regards. Quote
ter9999 Posted February 11, 2009 Posted February 11, 2009 Agree! And agree for the zoom-player-like drag function. Also, better to display the zoom rate in the OSD for some seconds like "97% zoom", "100% zoom", "101% zoom", "135% zoom", etc. when zooming. Can we also take usage of the "horizontal scroll" function of the mouse? Nowadays, lots of mouses have "horizontal scroll" besides the normal "vertical scroll" function for the middle key. I would like to use the "horizontal scroll" function to do resize, and the "Vertical scroll" function to do zoom. As long as these been realized in DVBViewer Pro!~ Quote
dyter Posted February 11, 2009 Posted February 11, 2009 Agree! And agree for the zoom-player-like drag function. Also, better to display the zoom rate in the OSD for some seconds like "97% zoom", "100% zoom", "101% zoom", "135% zoom", etc. when zooming. Can we also take usage of the "horizontal scroll" function of the mouse? Nowadays, lots of mouses have "horizontal scroll" besides the normal "vertical scroll" function for the middle key. I would like to use the "horizontal scroll" function to do resize, and the "Vertical scroll" function to do zoom. As long as these been realized in DVBViewer Pro!~ Yes same idea i have suggested last month ! Quote
ml 05019 Posted February 21, 2009 Posted February 21, 2009 If we continue about mouse (didn't want to start another topic for that): I noticed that mouse doubleclick is not used at all in DVBViewer. In most players I've been using before, its function is either play/pause, of toogle fullscreen on/off. So if possible, I'd like the doubleclick to be used in some way in DVBPlayer. P.S. The best option would be, IMHO, to set doubleclick function from Options -> Input window... Quote
Tjod Posted February 21, 2009 Posted February 21, 2009 I noticed that mouse doubleclick is not used at all in DVBViewer.Only if you deaktivat it (Options > Mouse) toogle fullscreen on/offIn DVBViewer to. Quote
ml 05019 Posted February 22, 2009 Posted February 22, 2009 Only if you deaktivat it (Options > Mouse) That's right, thank you. For some reason, it is disabled by default Quote
