Analog TV
figogo
Can anyone tells how to scan analog TV and what is the difference in the settings with Digital TV? Thanks for the help :(
Hello,
no analog. The DVBViewer only support DVB or ATSC transmissions.
Hello,
Thank You for your answer :)
BTW, I think this program is much better than the other. However, even Totalmedia supports analog but why this program doesn't? :(
analog transmissions arre doomed to stop.
Terestrial analog transmissions are not more available here in Belgium and is replaced with DVB-T transmissions.
For example:
One satellite transponder can deal with one analog channel.
The same transponder can send up to 10 digital channels so commercial seen, digital is the way to go.
This counts also for cable access or terrestrial.
And even DVB-S2/C2,T2 looks more promising .
Hello,
:angry:
:angry:
I am confused, I asked on a Swedish forum
http://www.tystpc.nu/forum/viewtopic.php?t=4025
and some very thrustworthy guys said it would work : using both digital FireDTV-C and Analog tuner (for cable)
using DVBViewer.
One guys specifically says it works with Hauppauge WinTV.
( Note that it is really the same antenna cable that sends both digital pay TV and free analogue channels,
I would like to record one whilst watching another ).
:biggrin:
it doesn't work. it never did, it never will. :angry:
