safai Posted February 11, 2009 Share Posted February 11, 2009 Hi, I use DVBViewer pro with skystar 2 card for sattelite reception in my PC. During the automatic scan, the weak signals are usually not identified, while if you enter the coordinates manually, they are too detected after some seconds of waiting. Is there a way to force DVBViewer to do a slower scan (i.e. to wait longer on each frequency) so that weaker-signal channels are also identified during the automatic scan? Thanks SAFAI Quote Link to comment
Tjod Posted February 12, 2009 Share Posted February 12, 2009 Use TransEdit for the channel search there you can change the timeout. http://www.DVBViewer.com/griga/TransEdit%2...w.html#Scanner2 Quote Link to comment
safai Posted February 12, 2009 Author Share Posted February 12, 2009 Use TransEdit for the channel search there you can change the timeout.http://www.DVBViewer.com/griga/TransEdit%2...w.html#Scanner2 Thanks a lot. I will give it a try. Quote Link to comment
safai Posted February 12, 2009 Author Share Posted February 12, 2009 Use TransEdit for the channel search there you can change the timeout.http://www.DVBViewer.com/griga/TransEdit%2...w.html#Scanner2 Tjod, Which timeout should I change? PAT, PMT ... ? Thanks Quote Link to comment
