Benjamin D Posted February 26, 2009 Posted February 26, 2009 Hi guys, Here is the "bug" I'm running into : on one channel, TF1 HD on the Canal+ set, I would not get the sound when I turn it on. The sound of that channel is dolby, either 2.0 or 5.1. DVBViewer is set up for AC3 audio to be handled by AC3 filter, other audio by ffdshow audio. To solve that, I would go to Edit Channel, and where the audio type is shown "AC3" I would put the audio type to "MPEG", and then hit Rebuild Graph. And then, I have sound (Dolby Digital, thru AC3 Filter). My work around is not elegant, can someone help me out on this one ? Is there some set up I need to change, or a way to make the change of audio type permanent ? (can Edit tool do that ?) Thanks in advance. Ben Quote
robob Posted May 14, 2009 Posted May 14, 2009 Hi guys, I'm sorry for my english again . I have the same bug than Benjamin : There are two Channel on the french Canalsat channels with no sound : TF1 HD and SCI-FI HD. When you choose the channel for the first time, there is no sound. If you choose the same channel twice the sound is ok. It's a problem if you want to record the channel there is no sound. This is not a codec problem : I have the same bug with all my h.264 codec and sound codec. I'm working on Windows XP SP3, Benjamin uses Vista. I ask myself why ARTE HD, France 2 HD or all the others HD channels are working fine and not these two channels ? The difference is that TF1 HD and SCI-FI HD have a English audio PID. All the others channels have only the French audio sound, except Arte HD with French and German audio PID. Arte HD is working Find. It seems that the problem comes from the existence of an English audio channel (problem with a default english audio PID ?). SCI-FI HD parameters SCI-FI HD English audio parameters : France 2 HD parameters : Quote
robob Posted May 18, 2009 Posted May 18, 2009 Hi, I can give you some log file or Transedit analyse if required... Quote
robob Posted May 28, 2009 Posted May 28, 2009 Hi, Nobody here ? Do you need something else ? Wiskey, French girl ? Quote
Griga Posted May 28, 2009 Posted May 28, 2009 Do you need something else? Wiskey, French girl ? Accepted. Please PM me for further details Check View -> Filters -> DVB Source when receiving one of the channels without audio. If the displayed audio state is "no data", DVBViewer doesn't get an (unencrypted) audio stream. Maybe a CI/CAM/hardware specific problem, so: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
robob Posted May 28, 2009 Posted May 28, 2009 ty for the answer, for the french girl it's here or here My support.zip When i choose the TF1 HD channel one time (no sound) the displayed audio state is "no data" : If i choose the channel twice (sound is ok) and i have data : Remenber that TF1 HD channel have exactly the same parameters than the others encrypted Canalsat HD channels. All other channels are working fine. A scan with transedit : Note that if i go into DVBViewer channel list editor and i replace the TF1 HD audio PID "94" by, for example "0", i apply and close DVBViewer : when i open DVBViewer, TF1 HD is working fine with sound and if i go into the channel list editor the audio PID is not "0" but "94" (how to force DVBViewer to accept a manual entry on audio PID ?). But if i change the channel and return on TF1 HD, the sound doesn't work. My card is a Floppy DTV S2 (HW ver. 01.24.04, FW ver. 1.5.2 BUILD 30740, driver 5.0.1) with cam Aston 2.18. Quote
Griga Posted May 28, 2009 Posted May 28, 2009 Note that if i go into DVBViewer channel list editor and i replace the TF1 HD audio PID "94" by, for example "0", i apply and close DVBViewer : when i open DVBViewer, TF1 HD is working fine with sound Due to the automatic channel update (see channel menu). It detects the wrong audio PID, corrects it and triggers a retune. IMO it's a CI/CAM issue. Most likely the stream remains encrypted on the first tuning attempt, for whatever reason. @Lars: As far as I can see the PMT of the affected channels contains a subtitle PID as first entry (in contrast to other CSAT channels, that show a different order), followed by two AC3 audio streams, finally H.264 video. All stream entries contain a CA descriptor, except subtitles... does it tell you something? Quote
Lars_MQ Posted May 28, 2009 Posted May 28, 2009 It doesn't matter. The Fire(Floppy)DTV is one of those cards which gets the whole unaltered PMT(buffer) send to the CI. The driver/CAM does handle the rest. So it is very likely a CAM problem. Quote
robob Posted May 29, 2009 Posted May 29, 2009 (edited) hi, i have done some more tests : i think there is a probleme between French and english audio PID. on TF1 HD and Sci-fi HD, the english Channel is... in french on the 2 PID (when i clicked twice on the channel to have sound). I looked on Canal + HD channel where the sound is ok and i have no sound on the English channel : when i clicked twice on the english channel the sound appear but it is french language... the automatic channel update is unclicked. Edited May 29, 2009 by robob Quote
Griga Posted May 29, 2009 Posted May 29, 2009 Hmm, TransEdit finds two SCI FI HD channels on 12669 V. They share the same video/audio/subtitle PIDs, but the Service IDs and the PMT PIDs are different: The first one 9922/1301, the second 9902/1281. Did you already try the second version? Any difference? However, the PMTs are identical, as far as I can see... I looked on Canal + HD channel where the sound is ok and i have no sound on the English channel : when i clicked twice on the english channel the sound appear but it is french language Seems the CAM isn't able to handle two encrypted AC3 streams properly. Quote
Derrick Posted May 29, 2009 Posted May 29, 2009 ..as far as I can see, the PMTs are identical. It could be the CI-module but I still have some doubts concerning the firedtv. There are more unsolved problems in particular with seca and simulcast. Quote
robob Posted May 29, 2009 Posted May 29, 2009 Hmm, TransEdit finds two SCI FI HD channels on 12669 V. They share the same video/audio/subtitle PIDs, but the Service IDs and the PMT PIDs are different: The first one 9922/1301, the second 9902/1281. Did you already try the second version? Any difference? yes, and i have two TF1 HD channels too with differents services IDs (see my Transedit printscreen) : the two SCI-FI HD and the two TF1 HD channels have the same probleme, no sound on the first time you choose it. Quote
robob Posted May 29, 2009 Posted May 29, 2009 (edited) My problem is to record the channel. For example, to record Battlestar Galactica sunday at 20:43 on SCI-FI HD, i have to open DVBViewer before and click twice the channel to have sound on my record. An other solution is to chose SCI-FI HD and change to Arte HD german and return on SCI-FI HD and the sound is ok : with this method, i can record without being here : i record 1 minute on SCI-FI HD, the next minute on Arte german and my progam after, like this : Edited May 29, 2009 by robob Quote
trougloubidchou Posted June 16, 2009 Posted June 16, 2009 (edited) Hello, I am facing the same issue with free to air channels using AC3, i do not have any sound. It works with crypted channels. The DVBSource filter show a "Enabled/Connected" state for audio. What could be wrong in may configuration ? In addition, i canno't read recording without sound but I can read other recordings. Thanks for your help. Regards. Jérôme Edited June 16, 2009 by trougloubidchou Quote
yolo Posted June 21, 2009 Posted June 21, 2009 HI robob, Exactly the same problem here, with the same channels. FireDTV + aston cam 2.18 Other channels are OK. Under Seven MCE, TF1 HD is working fine... Thanks for any help, Regards. Quote
iDCT Posted June 23, 2009 Posted June 23, 2009 Hi, Some french HD channels switched from AC3 audio to E-AC3. I had the "no audio" problem too, which was solved after I use ffdshow E-AC3 codec as AC3 codec in DVBViewer. You can download ffdshow filters > here < Hope this will help... Quote
robob Posted June 26, 2009 Posted June 26, 2009 Hi, Some french HD channels switched from AC3 audio to E-AC3. I had the "no audio" problem too, which was solved after I use ffdshow E-AC3 codec as AC3 codec in DVBViewer. You can download ffdshow filters > here < Hope this will help... I know that, but it is for the DVB-T Channels (Terrestrial channel, TNT) : I have a Pinnacle DVB-T card in my computer and all the TNT channels are working fine. My sound problem is specific to some DVB-S2 crypted Hd channel (Satellite): TF1 HD and SCI-FI HD on Canalsat. It is a initialisation problem when you first come on the channel. Quote
lems Posted January 7, 2010 Posted January 7, 2010 Hi, Any news on this topic because I have the same sound problem on SCIFI HD. Quote
