frazer Posted February 27, 2009 Share Posted February 27, 2009 Hello, I can't get DVBViewer to tune any DVB-T channels (I'm in the UK) with the Asus Tiger P7131E Hybrid tuner. I have tried all the XP BDA drivers available on the web, and the only difference is that using the latest two, DVBViewer shows a signal both on scanning and when tuning a channel (I have channels set up from a previous card still), but fails to actually find any channels at all. The card is though recognized by DVBViewer in the Options and is automatically selected when scanning. With the Asus TV software, all the channels are found and display properly, so the card and the signal strength are OK, but with GBPVR, I can only view channels from three transponders, although on scanning it finds channels on all six. Is there any explanantion for this behaviour someone can suggest? I have attached the support file, but it does seem to be very small for some reason, so I don't know if all the info is there. Thank you! Frazer support.zip Quote Link to comment
