bormoley Posted March 25, 2009 Share Posted March 25, 2009 Hello. I have 1.2 antenna on positioner with two LNBs on switch after positioner. (Because of using two types of LNB Ku and Circular) Is there a chance of using of all potential of my hardware? That means Can I automatically Rotate Antenna and Switch LNB's as already done on Progdvb I chose DVBviever because of Better interface for HTPC(I'm actually using). And it would be nice to make some kind of OSD Satellite switcher to navigate though satellites as Addition to my Proposal in http://www.DVBViewer.info/forum/index.php?...&pid=238870 . As for me it is not usable to have tree or flat channel list with remote (maybe I am mistaken/ that way guide me to some help or FAQ using Remote because used only Stationary receivers remotes ) Quote Link to comment
Griga Posted March 25, 2009 Share Posted March 25, 2009 Is there a chance of using of all potential of my hardware? With which DVB-S card resp. device? Quote Link to comment
bormoley Posted March 26, 2009 Author Share Posted March 26, 2009 With which DVB-S card resp. device? Technisat SkyStar HD2 (it has full diseqc support with new drivers) Quote Link to comment
Griga Posted March 26, 2009 Share Posted March 26, 2009 DVBViewer & SkyStar HD2 & DiSEqC 1.1/1.2 works (according to user reports). You may want to have a look at the TransEdit manual. TransEdit - a free add-on for purchasers of DVBViewer Pro - is a transponder list editor, scanner, DVB analyzer etc. It will give you an idea what is supported and how it is supported. http://www.DVBViewer.com/griga/TransEdit%20E/Content.html and particularly http://www.DVBViewer.com/griga/TransEdit%20E/DiSEqC.html Quote Link to comment
bormoley Posted March 31, 2009 Author Share Posted March 31, 2009 Hey there. Thanks for leading to manuals. I've tried to configure my PC but without success. So I've met such problems: -Firstly, it took some time for me to understand, that I do need to do all the steps (including channel scan and export it to DVBViewer) - because skipping some of manual of course -After having completed one of satellites I've met another problem: How to rename Screwed channels names? (I primarily use of EutelSat W4 NTV+ Russian) So trying to rename it in DVBViever 4.0 fail - nothing is doing / a no chance to do it in TransEdit. Upset smiley once more. -And the third one is all about setting next Satellite (I choose Sirius 2,3). After making presets and trying to scan it no channels were found and, what is interesting, no chance to go back to already scanned channels (on EutelSat W4). Only manual command to positioner to go to preset position helped. I did set up Satellites Extended commands like: 1. Positioner Goto x 2. Internal 100ms 3. Diseqc x I have one antenna with positioner and two LNBs on a switch after positioned. I am wondering if I did all right? And What to do to make all this stuff working Quote Link to comment
ITS A SCAM ! Posted April 4, 2009 Share Posted April 4, 2009 Hi there bormoley, have you had any luck yet ?? It appears that both of us are probably trying to do the same thing.... Quote Link to comment
bormoley Posted April 4, 2009 Author Share Posted April 4, 2009 Nope, I've stopped trying because I have no time to. I'm waiting (with my primary satellite preset) for somebody to help. Quote Link to comment
bormoley Posted April 9, 2009 Author Share Posted April 9, 2009 Nobody can help us with multiple satellites though positioner+Switch? P.S. Is there a chance to get option in new DVBViewer for chousing encoding while installation to Cyrilic for example (it will help with russian channels names) Quote Link to comment
bormoley Posted May 13, 2009 Author Share Posted May 13, 2009 Finally I've got it to work (Thanks to new DVBViewer Software starting 4.0.60) Thanks to developers for that. But thing there is steel some wrong functionality. So the problem is: After selecting channel from another satellite diseq commands are sent (at least one of them because positioner goes to selected position) but, to have a picture I need to switch to another channel on this satellite (or even to change transponder to get it to work). Can it be fixed somehow? Thanks anyway (I switch satellites very recently so it is not a kind of big problem to me). And one more thing. After some time, antenna changes its position a little because of wind etc. Is there a chance to move antenna using positioner with some signal strength indicator to get the best result (Actually I'd like to add one more satellite position too). If there is no such possibility - please recommend me some software to make this task done. Quote Link to comment
starman345 Posted May 14, 2009 Share Posted May 14, 2009 So the problem is: After selecting channel from another satellite diseq commands are sent (at least one of them because positioner goes to selected position) but, to have a picture I need to switch to another channel on this satellite (or even to change transponder to get it to work). Can it be fixed somehow? In settings-options-hardware, in the re-tune box, did you set a time or is it set to zero? If at zero, change it to 2 or 3 and see if your channel will tune after moving the dish. Quote Link to comment
bormoley Posted May 14, 2009 Author Share Posted May 14, 2009 In settings-options-hardware, in the re-tune box, did you set a time or is it set to zero? If at zero, change it to 2 or 3 and see if your channel will tune after moving the dish. Thank you for advise it works great! Quote Link to comment
