Watching *.ts file with other media player (inc subtitles)
Benjamin D
Hi Gents,
I'm doing pretty extensive recordings with DVBViewer 4.0.
I usually use DVBViewer to watch recordings, but in some instances, I'd like to watch the *.ts files I recorded (with 2 audio streams and 1 subtitle stream) with another media player. (most of the time on another PC, or while DVBViewer is working on main PC recording something else).
I tried Media Player Classic, which gives me access to the audio streams (with the internal splitter or with Haali splitter), but no way to get to the subtitles stream. I tried the VSFilter ON in the Haali menu, no change. I downloaded and installed DirectVobSub, which does not seem to be used/loaded by MPC.
Does anyone know how to make the subtitles work with Media Player Classic ? (with the *.ts "on the fly", in clear without going through the hassle of extracting the *.srt file and synchronising it)
Is there another player, that works best ? (VLC, other ?)
Thanks in advance.
Edited by Benjamin D
VLC works with TS, DVBSubs, Audiostreams.
Thanks Lars for the quick answer.
Unfortunately, I can't get VLC to actually display the teletext stream from the *.ts file
- I can switch from english audio to french audio and vice versa (same as MPC)
- The subtitle teletext stream is recognized by VLC (it is shown in the subtitle menu), but I can't succeed in displaying the content during the play... I loaded the right *.ttf font file for Windows, but nothing.
I guess I'll have to dig into the VLC forum... or dramatically improve my English to do without subtitles... ;)
Thx
Ah ttx subs. I though you meant dvbsubs. Well I don't know any other app than the viewer able to display this. ;)
..no problem with vlc. Maybe it depends on the page. Here's an example from the BBC ;)
@Lars, I have not tried the DVB subs yet... just struggling with the teletext right now ;)
@Derrick, can you share with us the settings for the teletext display ? I mean the font, size, etc and other set up for VLC ? (in the advanced folder I guess : Preferences > Video > Subtitles / OSD ??? )
Thx guys
I have only standard settings. What could make a difference is the version of the vlc. I'm using 0.8.6.i
