Commandline Plugin/Create Timer
Lars_MQ
Commandline Plugin 1.2
CLI to create timers in DVBViewer Pro, GE and Recordingservice. In the Membersarea.
Sorry I can't get the release notes formated correctly, so you have to read the readme here. ;)
The new parameters need the Recording service 1.4.7.100+!
in deutsch
Link to comment
  • 11 months later...
I'm using DVBViewer 4.2.1 and this plugin (dvbv_tvg.exe).
When I use a parameter -a 4, it does not work properly. (just work as "no action")
A readme says; 4 = Close DVBViewer //not for the Recording Service
I do not use the Recording Service.
Any suggestion?
Link to comment
  • 9 months later...
Commandline Plugin 1.2.3 can be downloaded from the membersarea.
Changes:
- Fix: Fixes for the -a parameter.
- Fix: Fixes for the detection of the running DVBViewer version.
Link to comment
  • 1 month later...
  • 3 years later...
I've been using ths in combination with DABDig to automate the recording service from DigiGuide. Is this still the best solution? What do other people use
to make recordings from Digiguide? I find the DVBViewer EPG ususable without favourite channels, especially from satellite.
Link to comment
