Abits Posted May 16, 2009 Posted May 16, 2009 Hi, i have a FloppyDTV-S2 and the last version of DVBViewer. I try Videorecorder Plugin Version: 3.4.4.2, men this not working. I use Canal Digital in norway. Please help. Quote
IRa Posted May 16, 2009 Posted May 16, 2009 Use TS format, select from "options/recorder/format options" teletext (or DVBsub but I think Canal plus uses teletext subs). You don't need videorecorder plugin for that. Quote
Abits Posted May 16, 2009 Author Posted May 16, 2009 Use TS format, select from "options/recorder/format options" teletext (or DVBsub but I think Canal plus uses teletext subs). You don't need videorecorder plugin for that. Hi. I use TS format, but there is not a subtiles, its only a mpeg ts files an not a TS subtiles files. Another software example progdvb give 2 files, one mpeg srt and one srt subtiles files. Quote
IRa Posted May 16, 2009 Posted May 16, 2009 Another software example progdvb give 2 files, one mpeg srt and one srt subtiles files.They are not in separate files, subtitles are included in TS file, you can see them is you watch your recordings using DVBViewer (or VLC) or if you want to make DVD from your recordings. Quote
Derrick Posted May 16, 2009 Posted May 16, 2009 When selected, the subtitle stream is part of the recorded TS and can be displayed during playback. If you want a separate text file, you have to use a tool (e.g. project.x) for extracting the subtitles from the TS. Quote
Abits Posted May 16, 2009 Author Posted May 16, 2009 (edited) They are not in separate files, subtitles are included in TS file, you can see them is you watch your recordings using DVBViewer (or VLC) or if you want to make DVD from your recordings. What settings do you have? Edited May 16, 2009 by Abits Quote
Abits Posted May 16, 2009 Author Posted May 16, 2009 I upload a file so you can se how this is, its not correct http://www.megaupload.com/?d=F05JTXDP Quote
Abits Posted May 16, 2009 Author Posted May 16, 2009 When selected, the subtitle stream is part of the recorded TS and can be displayed during playback. If you want a separate text file, you have to use a tool (e.g. project.x) for extracting the subtitles from the TS. project.x working fine Thanks for your and IRa helps. Quote
