aydan Posted May 24, 2009 Share Posted May 24, 2009 Hi, I'm missing kabeleins in the service's webinterface. Neither in the tvguide nor in the Timeline or the search can I find it in the listed channels. For ProSiebenSat.1 transponder I only see Sat.1, ProSieben, N24 and 9live. I've had this problem also in the 1.4 versions of the Service. Greetings Aydan support.zip Link to comment
Tjod Posted May 24, 2009 Share Posted May 24, 2009 Open the DVBViewer > channel editor > select kabel1 and make sure that Exclude from EPG is not tick and in the "EPG >" DVB EPG is tick. Link to comment
aydan Posted May 25, 2009 Author Share Posted May 25, 2009 Open the DVBViewer > channel editor > select kabel1 and make sure that Exclude from EPG is not tick and in the "EPG >" DVB EPG is tick. Strange thing is the tick in Exclude from EPG was set, although I always had EPG data for kabel eins. Testwise I set the webinterface to show channels without EPG also but I still don't see it. Link to comment
aydan Posted June 17, 2009 Author Share Posted June 17, 2009 I have no idea what exactly was wrong, but it seems my channels file was somehow corrupted. I just did a fresh scan after deleting all channels and now it works. CU Aydan Link to comment
