Dvb Viewer and avermedia remote control
Hi! I´ve already bought the DVBViewer program, and i think it is the best i´ve tested. The video image is clear and fluid.
I receive the dvb signal through an avermedia decoder (AVerTV DVB-T Super 007), and I would like to be able to control DVBViewer with the avermedia remote control. I installed the avermedia plugin, but it doesn´t work (the plugin is active in "options" - input).
I tryed with the "learn" utility in "options", but when I press the "learn" button, the program ask me to change the action of a key... but it asks once, and again, and again... and the screen is fulled with this dialog window. I have to stop running DVBViewer to become to normallity again.
If I uncheck the avermedia plugin, the learn options works perfectly.
¿What can I do to use properly the avermedia remote control?
Thank U in advance (and sorry for my english).
  • 3 months later...
Hmm, this is weird.... Can you test the attached plugin? Further Debug Messages can be displayed via Debugview.
Christian
myAverIR.zip
Christian
Hi
Thanks very much for your help , but it doesn't work for me.
  • 8 years later...
Hello,
Same for me; note that I do not see "learn" button in DVBViewer 6.1.1.0.
How DebugView could help? It prints two lines every time a key is pressed on the remote:
00000001    0.00000000    [4976]
00000002    0.00000000    [4976] procCharMsg called
00000003    0.20790711    [4976]
00000004    0.20790711    [4976] procCharMsg called
00000005    0.34388024    [4976]
00000006    0.34388024    [4976] procCharMsg called
Many thanks in advance. Antoine
oops! was my fault, I thaught AVER remote keys were already mapped by the plugin.
Using "Learn On" button in Options->Input, I mapped some remote's keys to actions and now it's fine.
  • 1 year later...
Hello,
I don't find AVER remote in settings, how can I configure remote ?
Thanks
