“No Hardware found”
Dogsday
:bye: Ever time I start DVBViewer (4.1.1.1) I get the message “no hardware found” – I get the 5 time before it kicks in and starts working – once I have OK'ed the 5 times it's great. – How do I stop this from happening?
Any good ideas? - Cheers
B) Ever time I start DVBViewer (4.1.1.1) I get the message “no hardware found” – I get the 5 time before it kicks in and starts working – once I have OK'ed the 5 times it's great. – How do I stop this from happening?
Do you have mediaportal installed or any other TV/HTPC software? These can hog your card leading to the 'no hardware found' message.
Good advice but all I have is DVB and Vista MediaCenter - not sure how I would take media center out. I use it for photo's and music so just want to turn off the TV part of it.
I've the same prolem with the New DVBViewer....
If you've a solution
Follow the instructions here :bye: .
Thanks you,
But I dont have Windows Media Center however I've the same probem
Actually my solution is to disconnect USB plug and after reconnect that
It seems to be a driver problem. Which hardware is used?
Could you post the support.zip (see above).
Regards
Prinz
Thanks you,
Do you have any other TV or HTPC software like gbpvr, mediaportal etc?
Regards
Prinz
Sure, it's in post 3 - I've stoped media center but still no luck, I'm still getting the same error 5 times before it kicks into life.
No I don't have any software or mediaplayer installed on my PC.
I've the problem everyday...
I've Technotrend S2 3650 USB
In the passed, all work perfect but when I install the last version of DVBViewer, I've this message every day, I can't understand.
I will send the support.zip soon, sorry but tonight I don't have the time
Does the same problem occcrs if the TV card is diasbled and enabled in the device manager of windows?
Regards
Prinz
Regards
Prinz
Good idea but still no luck, card disabled <reboot> enabled <reboot> and still getting the error 5 times before it starts to show a TV channel. Thanks for the idea was worth a shot. - please keep the idea's coming.
Have you found a solution yet to this problem?? I'm still stuck with it and am thinking about looking for other software as I'm really sick of this error.
IMO Prinz propose to <disable> and <reenable> the device without reboot...
So, disable, reenable and then try to see if DVBViewer works at first shoot...
If that work you can use devcon to revive your dongle before starting DVBViewer: more info in this post
:bounce:
