Cian Posted June 6, 2009 Share Posted June 6, 2009 Hi, Can anyone confirm for me if transponder dump is working from recording service? (1.5.0.2) Thanks. Link to comment
Cian Posted June 6, 2009 Author Share Posted June 6, 2009 (edited) Hi, Just did a quick check. If you set transponder dump in DVBViewer, it does not seem to carry over into Recording Service. Can you check please? Having said that, it seems easier to add the transponder dump in Recording service!! Thanks. Edited June 6, 2009 by Cian Link to comment
Lars_MQ Posted June 6, 2009 Share Posted June 6, 2009 Yes that's correct. It's written in the changelog. Link to comment
Rob100 Posted June 23, 2009 Share Posted June 23, 2009 (edited) Can you make this feature dump encrypted streams, ideally with the facility to enter the PIDS you want to keep, so more like a selective transponder dump Better still forget this idea and just make normal recordings write encrypted streams (complete with ECMs etc) to disc even without a CI attached. Transedit is a wonderful tool, but using it to do this isn't ideal. Hope I'm not going to get in trouble for suggesting this Edited June 23, 2009 by Rob100 Link to comment
