apprentice Posted June 6, 2009 Posted June 6, 2009 (edited) Can't move my diseqc motor (Stab HH120) via DVB-S2 card with this tool. There is no option. Read on some forums that people have had problems to move their motor with the actual retail version of transedit / DVBViewer. As there is no demo or software version available i can't test. Can i move my motor with this program? I move via programmed satellite positions. I don't use usals. Also the transedit demo tool does not recognize my Skystar 1 technotrend DVB card. Why? Edited June 6, 2009 by apprentice Quote
Griga Posted June 7, 2009 Posted June 7, 2009 Try the latest TransEdit test version that I've attached here: http://www.DVBViewer.info/forum/index.php?...st&p=248652 Some functions are disabled, but scanning should work. Read the TransEdit manual and particularly this chapter. You'll additionally need transponder lists (ini files) for the satellite positions that you want to receive and the latest BDA driver for the TT S2 3200. Quote
apprentice Posted June 7, 2009 Author Posted June 7, 2009 (edited) Thanks it works. Maybe i missed it in the manual, but would i have to run Transedit everytime when i want to move my dish to another position? Or will DVBViewer move the dish when i select a different satellite. Cause i read the positioner console is removed from the latest DVBViewer. Edited June 7, 2009 by apprentice Quote
Griga Posted June 7, 2009 Posted June 7, 2009 Or will DVBViewer move the dish when i select a different satellite. It will. Please read the "Hints for DVBViewer" sections in the DiSEqC chapter of the TransEdit manual. Quote
apprentice Posted June 7, 2009 Author Posted June 7, 2009 Unfortunately i had to revert back to old 5.0.0.19 Technotrend S2-3200 drivers, because i suffered no signal with several channels. It turned out the new drivers caused this. Will 5.0.0.19 still work alright with DVBViewer? Quote
apprentice Posted June 8, 2009 Author Posted June 8, 2009 Ok thanks for taking the time to answer my questions. Looks like i will be buying this program next weekend. Quote
