wappy Posted June 7, 2009 Share Posted June 7, 2009 (edited) Can some1 help me with the following problem? 1 cannot change sound setting on pch i can switch audio 1/2 but only the first 1 works seccond 1 dont give sound(checked box stream all audio enabled) 2 With HD programs i see the stream always as DTS with recording service not ac3 original(with netstream this working without problem) Also little question to owners of Technisat hd2 cards, is it normal that i loss signal on the dvb-s2 side of the card? i must always reboot whene signal is gone afterthat i have signal again but only for 10min than no signal anymore only on dvb-s channels.(using latest technisat drivers 1.1.1.302(twinhan driver give me error code 10 cannot start device) Sorry for my bad english. Edited June 7, 2009 by wappy Link to comment
Lars_MQ Posted June 7, 2009 Share Posted June 7, 2009 Do you use the current pch firmware? Link to comment
wappy Posted June 8, 2009 Author Share Posted June 8, 2009 Do you use the current pch firmware? Yes the latest from a few days ago. Link to comment
wappy Posted June 10, 2009 Author Share Posted June 10, 2009 No 1? is there meabya how to to fix it? Link to comment
wappy Posted June 13, 2009 Author Share Posted June 13, 2009 Tested with old firmware still the same problem, cannot hear second audio stream on pch only the firms stream works. Link to comment
