RiSaMa Posted June 7, 2009 Posted June 7, 2009 Good morning...: I bought last week DVBViewer but I can not properly record programs in high definition. Always, when I finish recording something with software created and analyzed the transportstream always "discontinuity." These are the things that I have: * A very good computer: i7, 6Gb, Seagate and Western Digital disks, 9800gtx ... * Operating system Windows 7 (x64), although I tried all: xp, xp sp2, XP SP3, Vista, .... * Hauppauge 4000 * All drivers updated! * I have tested thousands of codecs: coreavc, nvidia npure, Elecard, (all of hdpack ),.... * Signal Quality 92% (astra) I have also tested the VideoRec.dll, I said that there was no error, but then if you look at the MeGui, tells me that there are discontinuities ... These discontinuities, as encode the video in mkv audio lags me and many problems ... eac3to v3.16command line: "C:\Program Files (x86)\megui\tools\eac3to\eac3to.exe" "D:\Grabaciones\prueba.ts" 1:"D:\Grabaciones\T1_Video - .mkv" 2:"D:\Grabaciones\T2_Audio - Spanish.ac3" -progressnumbers ------------------------------------------------------------------------------ TS, 1 video track, 1 audio track, 0:06:01, 50i 1: h264/AVC, 1080i50 (16:9) 2: AC3, Spanish, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB, -1421ms [v01] The video track contains the (probably incorrect) "full range" flag. <WARNING> [v01] Extracting video track number 1... [a02] Extracting audio track number 2... [a02] Removing AC3 dialog normalization... [a02] Applying (E-)AC3 delay... [a02] A remaining delay of -13ms could not be fixed. [v01] Removing "full range" flag from video bitstream. [v01] Muxing video to Matroska... [a02] Creating file "D:\Grabaciones\T2_Audio - Spanish.ac3"... [a02] [0:04:59] The source file seems to be damaged (discontinuity). <WARNING> [v01] [0:04:59] The source file seems to be damaged (discontinuity). <WARNING> [a02] This track is not clean. <WARNING> [a02] [0:05:29] The source file seems to be damaged (discontinuity). <WARNING> [v01] [0:05:29] The source file seems to be damaged (discontinuity). <WARNING> [v01] Video has a gap of 43 frames at playtime 0:05:28. <WARNING> [v01] Video has a gap of 219 frames at playtime 0:05:28. <WARNING> [v01] The MKV file was created without making use of the gap/overlap information. <WARNING> [v01] Please check whether audio is in sync. If it is in sync everything is fine. <WARNING> [v01] Otherwise ask eac3to to repeat the muxing. It will then automatically make <WARNING> [v01] use of the detailed gap/overlap information. <WARNING> [a02] Audio has a gap of 160ms at playtime 0:04:58. <WARNING> [a02] Audio has a gap of 800ms at playtime 0:05:28. <WARNING> [a02] Starting 2nd pass... [a02] Realizing (E-)AC3 gaps... [a02] Creating file "D:\Grabaciones\T2_Audio - Spanish.ac3"... Added fps value to MKV header. Video track 1 contains 17951 fields. eac3to processing took 27 seconds. Done. I hope you can help ... thank you very much PS: Sorry for my bad English ... Quote
RiSaMa Posted June 8, 2009 Author Posted June 8, 2009 Well ... can anyone help me? I purchased this program to record high definition and I can not ... if these problems ... Please I need help! Thank you very much Quote
Gioxy Posted June 8, 2009 Posted June 8, 2009 ...don't be fooled by 92% quality, but check instead if there are also reception discontinuity in "View / Filters / DVB Source"... You can see it "live" and/or set "Write log file" and "Write extended log file" in "Setting / Options / Recordings" to know the recording "quality" (perhaps better to read it... continuity) before you process it... If they are, you have to double (or triple) check your dish, cable, DiSEqC, connection and whatsoever there are between your Hauppauge 4000 and the sat... I'm quite sure you already know that a bad wheather can blind your sat reception... some sat card (for example the good old SkyStar 2) are also "disturbed" by DECT phones if too near... BTW: Windows 7 isn't (at least ATM) a good/strong HTPC choice: if you can, rebuild you PC with XP Sp3... Quote
RiSaMa Posted June 12, 2009 Author Posted June 12, 2009 ...don't be fooled by 92% quality, but check instead if there are also reception discontinuity in "View / Filters / DVB Source"...You can see it "live" and/or set "Write log file" and "Write extended log file" in "Setting / Options / Recordings" to know the recording "quality" (perhaps better to read it... continuity) before you process it... If they are, you have to double (or triple) check your dish, cable, DiSEqC, connection and whatsoever there are between your Hauppauge 4000 and the sat... I'm quite sure you already know that a bad wheather can blind your sat reception... some sat card (for example the good old SkyStar 2) are also "disturbed" by DECT phones if too near... BTW: Windows 7 isn't (at least ATM) a good/strong HTPC choice: if you can, rebuild you PC with XP Sp3... View-> Filters-> DVB Source I do not see any error ... In the log record does not exist error ... The Hauppauge 4000 works well. Sure the antenna is OK. I have no device that can interfere ... I tried many times on xp and I will not change again (as they would lose the 6Gb of RAM). I remain the same ... Sometimes shooting well (minimum) and others do not ... I recommend! What can I do ¿?!!! THANKS! Quote
Etienne Posted June 13, 2009 Posted June 13, 2009 View-> Filters-> DVB Source I do not see any error ... In the log record does not exist error ... The Hauppauge 4000 works well. Sure the antenna is OK. I have no device that can interfere ... I tried many times on xp and I will not change again (as they would lose the 6Gb of RAM). I remain the same ... Sometimes shooting well (minimum) and others do not ... I recommend! What can I do ¿?!!! THANKS! If you record the channel with Transedit, did you have the problem ? (for this, you must know the corrects pids , look at channel edit menus) Quote
RiSaMa Posted June 13, 2009 Author Posted June 13, 2009 How was recording with transedit? I have recorded by record .... (the red button). By the way, if you schedule a recording and not recording DVBViewer this off .... (or is turned ....) Quote
RiSaMa Posted June 13, 2009 Author Posted June 13, 2009 Log: C+ DEPORT HD (spa) 13/06/2009 C:\Grabaciones\06-13_C+ DEPORT HD (spa)_RED WINGS - PENGUINS (5°) (HD).ts Device: Hauppauge WinTV 88x DVB-S/S2 Tuner/Demod (2) 11:20:46 / 0:00:00 (~ 0,0 MB) Start 11:20:46 / 0:00:00 (~ 1,4 MB) PID 161: H.264 Video, 16:9, 1920x1088, 24,9999996076687 fps 11:20:46 / 0:00:00 (~ 1,4 MB) PID 84: AC3 Audio 5.1, 48,0000013083083 khz, 384 kbps 11:25:08 / 0:05:37 (~ 605,1 MB) Errors: 2 11:33:52 / 0:11:15 (~ 1106,9 MB) Stop Average Data Rate: 1,640 MB/s Total Size: 1106,9 MB (1160709556 Bytes) Quote
RiSaMa Posted June 16, 2009 Author Posted June 16, 2009 Please can someone help me? What can be my problem? Thanks! Quote
Gioxy Posted June 16, 2009 Posted June 16, 2009 Try to read this post, perhaps your prob it's related to similar settings... Quote
RiSaMa Posted June 23, 2009 Author Posted June 23, 2009 I still have the same problem .... I have all codecs and drivers updated. Anyone could help .... I no longer know what to do ... I desdesperado! The sending me the log that creates the DVBViewer ...: C+ DCINE HD (spa) 22/06/2009 F:\*.ts Device: Hauppauge WinTV 88x DVB-S/S2 Tuner/Demod (2) 20:03:00 / 0:00:00 (~ 0,0 MB) Start 20:03:03 / 0:00:03 (~ 2,3 MB) PID 80: AC3 Audio 5.1, 48 khz, 384 kbps 20:03:04 / 0:00:04 (~ 4,0 MB) PID 160: H.264 Video, 16:9, 1920x1088, 25 fps 20:12:52 / 0:09:52 (~ 798,3 MB) Errors: 2 20:56:42 / 0:53:42 (~ 3673,5 MB) Errors: 2 21:20:52 / 1:17:52 (~ 4930,2 MB) Errors: 2 22:00:00 / 1:57:00 (~ 7446,3 MB) Stop Average Data Rate: 1,061 MB/s Total Size: 7446,3 MB (7808007916 Bytes) Thank you very much! Quote
Gioxy Posted June 23, 2009 Posted June 23, 2009 Have you checked the post I told you? (you don't mention about it...) Quote
RiSaMa Posted June 25, 2009 Author Posted June 25, 2009 Yes, yes and disable C1E and still the same problem .... Please I need help! Someone can tell me where the problem can come .... Thank you very much! Quote
Gioxy Posted June 25, 2009 Posted June 25, 2009 Too many thing to guess... But as your DVBViewer logs state that there were errors AFAIK they most likely be signal or maybe CI related... BTW, have you already tried to use Recording Service or to record with A/V disabled? Another hint is to try to check "Conifuración / Opciones / Avanzado / Usar solo la primera CPU" and in the same page "Prioridad = Normal"... Quote
RiSaMa Posted June 25, 2009 Author Posted June 25, 2009 If you've tried it with A / V off, with the same result (failure). In this section of the configuration I tested with normal priority, high. And with many cores .... The HD channels are not the records without any kind of error, so I do not think that problem is not IQ or signal .... also fail because the SD channels ... Any ideas ....? ¡¡I'm desperate! THANK YOU Quote
RiSaMa Posted June 26, 2009 Author Posted June 26, 2009 I must say that I'm wrong on the last post. Programs in SD also gives the same errors! Any idea ¿?.... think that it can be .... Quote
