byrnefm Posted June 16, 2009 Posted June 16, 2009 Hi, I am a very newbie to DVBViewer Basically, I am trying to determine if the DVB-T card that comes with my computer can be controlled with DVBViewer so I downloaded TransEdit to see if it can detect my card. However, I don't know how to ask the program to scan the airwaves for DVB-T - only for satellite! Apologies if this is a very silly question but how do I scan for DVB-T channels using TransEdit? (I know the signal I want is on PAL UHF ch 35). Thanks in advance! Quote
Gioxy Posted June 16, 2009 Posted June 16, 2009 Welcome aboard byrnefm... how do I scan for DVB-T channels using TransEdit? (I know the signal I want is on PAL UHF ch 35 Assuming you are talking about TransEdit MMC Demo you have to: • on the left panel, select a "Terrestrial (...)" predefined Trasponder List correspondent to your country/continent • find out (Google is your friend) witch frequency correspond in your country to ch 35 • select on the right panel this frequency and click on "Scan selected" • in the new window that appear, after the scan is completed, you can preview the founded channel double clicking on it Quote
byrnefm Posted June 17, 2009 Author Posted June 17, 2009 Welcome aboard byrnefm... Assuming you are talking about TransEdit MMC Demo you have to: • on the left panel, select a "Terrestrial (...)" predefined Trasponder List correspondent to your country/continent • find out (Google is your friend) witch frequency correspond in your country to ch 35 • select on the right panel this frequency and click on "Scan selected" • in the new window that appear, after the scan is completed, you can preview the founded channel double clicking on it Thank you for replying so quickly! I will give it a try. Quote
byrnefm Posted June 24, 2009 Author Posted June 24, 2009 (edited) Thank you for replying so quickly! I will give it a try. I gave it a try and after several attempts, found a mux listed However, when I click on Preview for any channel, I get the following error: Zugriffsverletzung bei Adresse 004BFBE1 in Modul 'TransEdit.exe'. Lesen von Adresse 000002BC. Is this a bug? [Replying to self] - seems to be something of the sort as re-starting TransEdit did the trick and I can preview channels now. Edited June 24, 2009 by byrnefm Quote
Gioxy Posted June 24, 2009 Posted June 24, 2009 So good: that's mean that your card can be used with DVBViewer Pro... BTW, witch card (manufacturer & model) is it? And what's name give it Transedit? (...can be usefull for others...) Quote
