Error 0X80040218 - Unable to Render
Ian C
Experimenting with Windows 7 caused a catastrophic failure (corruption) on my main system, Windows Xp SP3.
Re-installed my Win Xp SP3 and all seems to be fine BUT>>
Having downloaded and installed DVBViewer 4.1.1.1 everything appears OK but there is no picture and I get the message
"DVB Pro Error - CANNOT RENDER MEDIAFILE/OUTPUT PIN 0x8004218, Error: NO COMBINATION OF FILTERS CAN BE FOUND TO RENDER THE STREAM"
DVBViewer 4.0.1 was working fine bfore the crash... Am I missing something or has the re-installation of Win Xp SP 3 omitted something.
So far as I can ascertain all my system parameters are the same as before the failure.
Can anyone assist in my diagnosis please??
Thanks Ian Clarke..
post support.zip
Usual a driver/ mpeg decoder problem.
if your look under options, directX, does it menten auto, change that and select a specific device.
Thanks Ian Clarke..
Benarty,
Many thanks for your expert advice. I did have several codecs on my system, Ligos and ffdshow, included, but for some reason they were not manifesting. I downloaded a codec pack from CODECS.COM and BINGO!!! all sprang to life.
Investigating the loss of the original Elcard Codecs the directory was there but the files. . . . gone.???
I have been a user of DVBViewer for some 5 years now and find it to be a superior alternative to all the others.
Once agian, sincere thanks for your invaluable help.
Kindest regards,
Ian Clarke.. (Happy Bunny)
Edited by Ian C
