AndersB Posted June 20, 2009 Share Posted June 20, 2009 DVBViewer crashes when I try to open a MKV file. The same files work just fine both in Windows Media Player 11 and MPC. In the Windows eventlog, there is a event about an error caused by DVBViewer.exe. I've tried different decoders and also re-install directx without success. Would appreciate if someone knows why this happens only in DVBViewer and not in any other application. support.zip Quote Link to comment
dvbrewer Posted June 20, 2009 Share Posted June 20, 2009 (edited) DVBViewer crashes when I try to open a MKV file. The same files work just fine both in Windows Media Player 11 and MPC. In the Windows eventlog, there is a event about an error caused by DVBViewer.exe. I've tried different decoders and also re-install directx without success. Would appreciate if someone knows why this happens only in DVBViewer and not in any other application. Do you have an MKV splitter installed - i.e. Matroska/Haali, MPC-HC, or DivX? Edited June 20, 2009 by dvbrewer Quote Link to comment
AndersB Posted June 20, 2009 Author Share Posted June 20, 2009 Of course. Haali. Also tried the one from MPC-HC but no change - still makes DVBV crash. Quote Link to comment
