BUGlet = a little confusing (I think there may be 2 of them)
CellZapper
as a result of my trying to get my compro s350 diseqc working I came across this minor problem (but it gets you going round in few circles, before you realise it don't mean it)
got to channel editor in DVBViewer, and setup diseqc on satellite level.
select diseqc preset pos
set preset position to a value , in this case 3
apply and move to another sat (to set this new sat diseqc up)
Go back to original sat
the position number has changed to a number reflecting its angular position DUH!!! o:)o:)
very confused
set diseqc setting to "none" is a quick way to reset position number to zero. (because you have to click it down you can't type a new number in)(I supose that is another BUGlet)
I went around the loop several times before I found that the channels on the sat had been set correctly to the position number I was inserting.
Can something be done so when returning to check/reset the diseqc position on a satellite that the position is correctly set to the one I put in, not the angulsr position.
Regards chris
support_plus.zip
Edited by CellZapper
Thanks for feedback. Will be fixed in the next beta release.
Thanks Griga
You are a star.
Regards Chris
Well, actually Lars has fixed it. I've only drawn his attention to it.
