dr.punk Posted July 16, 2009 Posted July 16, 2009 Hello DVBViewer Forum, First of all, I wanna have a networkstream from my DVBViewer to the VLC-Player. After a new installation of DVBViewer 4.1.1 I noticed there are no possibilities to catch the stream, though the NetStream Plugin was enabled anyway. In the next step I noticed that the RecordingService was not installed with new DVBViewer, so I installed the RecordingService afterwards. After that, no DVBViewer was working anymore: "Bitte überprüfen Sie die Konfigurationseinstellungen und installieren Sie diese erneut..." - this or some similar... From that way I deinstalled DVBViewer (include the RecordingService) - restart the PC - and installed DVBViewer again. Everything is allright, except the RecordingService and the NetStream-Technology... Has somebody any hint, whats to do... ? The problem is not the RecordingService, the problem is the netstream. In my opinion this Service is necessery to run the NetStream? Is this right? My Hardware: KNC-One + support.zip Thanks a lot for your possible help, regards, matthias support.zip
Lars_MQ Posted July 16, 2009 Posted July 16, 2009 Well this happens if you don't care to read the changelog. You do have a color monitor, don't you? then you should see the bold writing in red
