Restart dvbservice via webinterface | Process task?
since I`m completely dump when it is comming to scripts/tasks etc. I would like to ask for help creating a task that will restart the dvbservice.
I`m using mostly the streaming/transcoding capabilities of Recording Service and very offten program hungs. Since I`m far waway from the computer I stuck in dead end.
Please advise me.
Link to comment
I triedt to perform the restart with a .bat file.
net stop DVBVRecorder
net start DVBVRecorder
Unfortunately it is stoping the service but is not able to start it again.
Any ideas ?
Link to comment
Maybe this helps:
Google for shutdown.exe and how to use it.
This is a Microsoft prog for shutdown or reboot.
It works differently according to your OS.
This will not only restart the Service but the whole PC, but until there are a better way....
Then you should try to activate the shutdown.exe as process task in the recservice webinterface (page Timers --> link Tasks)
Please let us know if it works, for other people searching this.
Edited by Devastation
Link to comment
Thanks for your replies.
As toi shutdown I was thinking about this but this would be the final solution.
@Lars I would like to execute a BAT file locally via Webinterface, so DVBService will only take care of launching a BAT file.
But I have doubt if stop/start dvbvrecorder could not be replaced with a command pointing to dvbvservice.exe with stop and start parameters.
Link to comment
