alex shin Posted August 7, 2009 Share Posted August 7, 2009 hello, Just upgraded to 4.2 and i realy hoped the problem will be solved but.. I can see the subtitles descriptions for each channel (heb,rus,ara) but no subtitles displayed on the screen Please help!!! Link to comment
alex shin Posted August 7, 2009 Author Share Posted August 7, 2009 does the osd work? yes, the osd works Link to comment
Lars_MQ Posted August 7, 2009 Share Posted August 7, 2009 could you please provide a (round about) 30 seconds TS recoding with subtitles (see options -> recordings) of the channel in question so we can check where the problems is? Link to comment
alex shin Posted August 7, 2009 Author Share Posted August 7, 2009 could you please provide a (round about) 30 seconds TS recoding with subtitles (see options -> recordings) of the channel in question so we can check where the problems is? Can you give me specific instructions for ts recording please ? Link to comment
Lars_MQ Posted August 7, 2009 Share Posted August 7, 2009 in Options -> Recorder set the output format to TS and the format options to DVB Subtitle and Adjust PAT/PMT. Then tune a channel with the problematic subtitles and do a normal manual recording for 30 - 45 seconds. If you don't have webspace available you can use rapidshare.com or similar to upload the ts file and PM me the URL so I can download and examine the file. Link to comment
alex shin Posted August 7, 2009 Author Share Posted August 7, 2009 http://www.acc.co.il/yes.ts Link to comment
leo1971 Posted August 7, 2009 Share Posted August 7, 2009 hello, Just upgraded to 4.2 and i realy hoped the problem will be solved but.. I can see the subtitles descriptions for each channel (heb,rus,ara) but no subtitles displayed on the screen Please help!!! Here in Brazil same problem, in my other micro (intel - skystar HD). the subtitle was plain text DVB Subtitles, and 2 bit DVB Subtitles and never worked in version 4.1 or less. Than i friend of mine installed beta version: Change log: Add: Added support for plain text DVB Subtitles. Add: Added support for 2 bit DVB Subtitles. And told me its works. Than I installed 4.2.1.0 i saw 1 time subtitle working in one channel. but almost all time 2 bit dvb and text dvb do not working. Then maybe some trouble from last beta to last final realese. I canot install beta anymore because its expire, i am waiting my friend instal 4.2.1.0 to see if subtitle will work. Thanks. Link to comment
Lars_MQ Posted August 7, 2009 Share Posted August 7, 2009 @alex shin OK technically there are no subtitle Streams in your file. They are announced but don't show up. Since you have 6 Streams to be decrypted (1xVideo, 2 x Audio, 3 x DVBSubs), my guess is: your CAM can't handle that much streams. Which dvb hardware and which CAM are you using? Link to comment
alex shin Posted August 7, 2009 Author Share Posted August 7, 2009 @alex shinOK technically there are no subtitle Streams in your file. They are announced but don't show up. Since you have 6 Streams to be decrypted (1xVideo, 2 x Audio, 3 x DVBSubs), my guess is: your CAM can't handle that much streams. Which dvb hardware and which CAM are you using? Haupauge wintv-88x [removed] § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. http://www.DVBViewer.info/forum/index.php?act=boardrules Link to comment
Lars_MQ Posted August 7, 2009 Share Posted August 7, 2009 well, get a dvb-device with a CI and use a legal cam and then you can ask again. Thread closed. Link to comment
