Right_Hoot_912 Posted August 9, 2009 Posted August 9, 2009 Hi, I'm using Recording service with 5 DVB-s cards .. Every thing works great . but is there a way I can watch videos while they are being recorded by the service? I can see the the videos in the recording list in DVBViewer but only after the recording ends.
Devastation Posted August 9, 2009 Posted August 9, 2009 Update to the new version. Here it works without problems. If you have new version or still have this problem with new Version: http://www.DVBViewer.info/forum/index.php?showtopic=2210
Right_Hoot_912 Posted August 9, 2009 Author Posted August 9, 2009 Update to the new version.Here it works without problems. If you have new version or still have this problem with new Version: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Thank you for your reply. I'm using the latest version. DVBViewer : 4.2.1.0 Recording Service : 1.5.0.25 I attached the Support.zip file. Hardware: 3 x hauppauge wintv nova-s-plus (Preferred) Driver 2.123.27056.0 1 x TeVii S470 DVB-S2 PCI-E . Driver 20090617 1 x Videomate s500 USB . Driver 2.87.0.44 Chipset: Gigabyte P43 Chipset. VGA: ATI Radeon HD 4870 driver 8.620.0.0 support.zip
Devastation Posted August 9, 2009 Posted August 9, 2009 (edited) Looks good for me. Only thing I found are maybe the Recordingfolders I had the same problem (but with a DVBV over network, not on the same PC like RecService) and the solution was Unc-Paths for the Service Recordingfolders. Please try it. Edited August 9, 2009 by Devastation
Right_Hoot_912 Posted August 9, 2009 Author Posted August 9, 2009 (edited) I will try it now. but maybe this is the problem.. I found this on the link u gave me. Now open in DVBViewer Pro Settings --> Options the point Recorder. Here delete all recording directorys that you want to use in RecordingService. There must be minimum one recording directory for instant timers which must not be equal to one of the directory in the RecordingService. I'm using the same recording folders for the service and DVBViewer. Edited August 9, 2009 by Right_Hoot_912
Devastation Posted August 9, 2009 Posted August 9, 2009 Have overseen this. Good correct this and test it and if it dont work then go to the unc-path step. So we can see what of both things was responsible. (if one of those)
Right_Hoot_912 Posted August 9, 2009 Author Posted August 9, 2009 didn't work I created 3 separate folders : 1-DVBViewer 2-Service 3-Timeshift and i tried the unc-path .. and it didn't work. I found a temporary solution . I added the service recording folder to Movies virtual-path list.now i can watch the videos while they are being recorded.
Devastation Posted August 10, 2009 Posted August 10, 2009 For me it works perfectly under XP, maybe its Vista? But thats wild guessing.
Right_Hoot_912 Posted August 10, 2009 Author Posted August 10, 2009 For me it works perfectly under XP, maybe its Vista? But thats wild guessing. yes I'm using vista .. Maybe they will fix this in the next release .. Thank you for trying to help me
