hackbart Posted August 9, 2009 Posted August 9, 2009 Hi, we are currently working on the mheg5 support for english and new zealandish channels. The interpreter is working partially and we honestly need test samples in order to do a valid stress test. It would be nice if everybody who is able to receive mheg 5 related services would dump the pids by using either the mhp plugin, or via transedit. Christian Quote
Cian Posted August 10, 2009 Posted August 10, 2009 MHEG5 is in the standards for Irish DTT also, but I don't think that they are transmitting it yet (Irish DTT is still only in the test stage at the moment). Would it be listed as MHEG5 in Transedit? Quote
hackbart Posted August 10, 2009 Author Posted August 10, 2009 The si information should be flagged correctly. Christian Quote
hackbart Posted August 12, 2009 Author Posted August 12, 2009 The interpreter is progressing and all my BBC/ITV samples are working nearly 100% like they should. Anyway we need samples in order to improve the engine. Especially samples from new zealand, hong kong and australia would be great. Christian Quote
SimonP Posted August 14, 2009 Posted August 14, 2009 Excellent, I'm looking forward to that. Will it be a plug-in or integrated into DVBv? Do you need any more UK samples? Quote
hackbart Posted August 14, 2009 Author Posted August 14, 2009 The more samples we can get the better. If you could drop me a mail, i will send you a transedit version which will save the mheg data automatically. There is no need for a complete transport stream dump. It would be nice if there are some customers from new zealand, or hong kong willing to support us with dumps. This would really speed up our internal tests We will integrate the Mheg 5 support directly into the DVBViewer, and we will also publish the source code for the Interpreter under GPL. Christian Quote
dacraka Posted August 16, 2009 Posted August 16, 2009 The more samples we can get the better. If you could drop me a mail, i will send you a transedit version which will save the mheg data automatically. There is no need for a complete transport stream dump. It would be nice if there are some customers from new zealand, or hong kong willing to support us with dumps. This would really speed up our internal tests We will integrate the Mheg 5 support directly into the DVBViewer, and we will also publish the source code for the Interpreter under GPL. Christian Yea I live in New Zealand and use DVBViewer with our DVB-T service - happy to help. Quote
kryses Posted August 16, 2009 Posted August 16, 2009 Hi, I have been using DVBViewer in New Zealand to receive out DVB-T broadcast. I'm not very technical, but if I can help I would be pleased to assist. I am using Leadtek PXDTV1300 and DTV2000H Tuners. Quote
Lars_MQ Posted August 16, 2009 Posted August 16, 2009 the procedure is quite simple, so there should be no real problems. You just have to know how to use WinRAR (it does compress this kind of data to a fraction of it's size) and how to make the rar files available via a downloadservice like rapidshare or similar (because the files are most likely over the 10 MB the magic limit of the mailserver). If you're comfortable with these requirements just PM Hackbart. The more samples we get the better. In germany we don't have MHEG-5, so we have to depend on your support to make it work for you. Quote
dvbnzer Posted August 16, 2009 Posted August 16, 2009 If you require more samples, or someone to test the plugin in New Zealand, I'm happy to help. Quote
allstarnz Posted August 17, 2009 Posted August 17, 2009 should it stop after a while, or do I just stop it after that long? I left it going for 50 mins and it still hadn't stopped doing its thing Quote
Lars_MQ Posted August 17, 2009 Posted August 17, 2009 you should stop it after 5-10 minutes (press the record si tables button again). that's enough data for us. Quote
allstarnz Posted August 17, 2009 Posted August 17, 2009 you should stop it after 5-10 minutes (press the record si tables button again). that's enough data for us. thanks, will do it for 10 mins. Quote
dacraka Posted August 17, 2009 Posted August 17, 2009 Just to help some NZ'ers out if you don't know what to do - Select "Terrestrial (EUR)" in the TransEdit program you will be sent via email, then you can choose (select) one out of the following frequencies to "Analyse": 538 570 666 There are more but I have just put three to give you an example. Quote
hackbart Posted August 17, 2009 Author Posted August 17, 2009 Thanks with the help of those files we where able to test our Mheg engine. As you can see it seems to work like it should If there is a hong kong user able to provide us with the same information we could also test the mheg compatibility there... Christian Quote
mentalinc Posted August 17, 2009 Posted August 17, 2009 (edited) Thanks with the help of those files we where able to test our Mheg engine. As you can see it seems to work like it should If there is a hong kong user able to provide us with the same information we could also test the mheg compatibility there... Christian Looks great, any plans to release a beta? Edited August 17, 2009 by mentalinc Quote
hackbart Posted August 17, 2009 Author Posted August 17, 2009 Not yet, but we plan to offer a full working final solution definitively this year. Christian Quote
dacraka Posted August 18, 2009 Posted August 18, 2009 Thanks with the help of those files we where able to test our Mheg engine. As you can see it seems to work like it should If there is a hong kong user able to provide us with the same information we could also test the mheg compatibility there... Christian Yea that's what it should be looking like! Great stuff : ) Quote
Gary Lam Posted August 18, 2009 Posted August 18, 2009 Thanks with the help of those files we where able to test our Mheg engine. As you can see it seems to work like it should If there is a hong kong user able to provide us with the same information we could also test the mheg compatibility there... Christian Just reply for your e-mail How can I collect the Hong Kong MHEG5 data for you ? Quote
York Posted August 18, 2009 Posted August 18, 2009 I'm a user from Hong Kong too..! so how I can help you to test with the MHEG5 function ? Quote
hackbart Posted August 18, 2009 Author Posted August 18, 2009 Just drop me an email and i will send you some instructions. Christian Quote
KinKong Posted August 18, 2009 Posted August 18, 2009 Iwould like to help too. But I can't capture the stream of MHEG in some of time by using the plugin. Is it OK? Quote
allstarnz Posted August 19, 2009 Posted August 19, 2009 so you'll use the MHEG5 info to populate the EPG as well? Quote
hackbart Posted August 19, 2009 Author Posted August 19, 2009 No, mheg5 will be displayed inside the osd. Christian Quote
hackbart Posted August 19, 2009 Author Posted August 19, 2009 The Mheg transmissions in Hongkong also seem to work - at least partially. There is a unicode display problem which needs to become fixed, as well as some weird behaviours caused by Invalid actions fired by the Mheg Application. Either its a bug in our interpreter, or a problem caused by the provider. Christian Quote
Gary Lam Posted August 20, 2009 Posted August 20, 2009 The Mheg transmissions in Hongkong also seem to work - at least partially. There is a unicode display problem which needs to become fixed, as well as some weird behaviours caused by Invalid actions fired by the Mheg Application. Either its a bug in our interpreter, or a problem caused by the provider. Christian I had sent you another TS contains new MHP functions. Please test. Thanks Quote
allstarnz Posted August 26, 2009 Posted August 26, 2009 so what use is this then when you can't use the data for the EPG? Our terrestrial EPG is only available in MHEG5, there is no EIT data for EPG Quote
Lars_MQ Posted August 26, 2009 Posted August 26, 2009 This is a question you should ask your broadcasters, not us. Quote
allstarnz Posted September 1, 2009 Posted September 1, 2009 This is a question you should ask your broadcasters, not us. ok, so perhaps I'm a little ignorant here, but why should it be the broadcasters problem? As I understand it, part of the MHEG5 data includes EPG information, which can then be extracted to populate a TV guide, much the same as what STB makers such as Zinwell have done. This can then be used to populate EPG for PVR functionality and such. Surely this would not be the aim of this exercise as well then? Please correct me if I'm wrong about this. Quote
Lars_MQ Posted September 1, 2009 Posted September 1, 2009 Because there is already a fully working way to do it: Transmit the EPG in the EIT like everybody else does it. Every DVB receiver can work with it out of the box. There is simply no sane reason to make a MHEG EPG. And there is no reason to write a complicated conversion just to undo (and support) the stupidity of some broadcasters in one country. Quote
allstarnz Posted September 1, 2009 Posted September 1, 2009 Because there is already a fully working way to do it: Transmit the EPG in the EIT like everybody else does it. Every DVB receiver can work with it out of the box. There is simply no sane reason to make a MHEG EPG. And there is no reason to write a complicated conversion just to undo (and support) the stupidity of some broadcasters in one country. oh, ok. Though I don't agree with your rationale, thanks for putting your view across. here are two answers from Freeview NZ in regards to non-transmission of EIT data. I suspect we won't be the first country to only submit EPG data via MHEG5 12. When does Freeview plan on including EIT data in your HD broadcast? The Freeview broadcasters decided to broadcast the EPG data only within the MHEG data stream and not use EITsch data because this uses about one tenth of the bandwidth. If the EITsch data was broadcast separately not only would the cost be substantially more for the bandwidth but the same amount of channels and services could not be provided using the current frequencies. 12. Will MHEG5 be loosened up so that non-Freeview approved STBs can make use of a full 8-day EPG. This includes the Play TV add-on for the PS3. Mheg-5 is open standard and all the major TV manufacturers and stand alone receiver manufacturers as well as a number of products in development use this standard to populate the 8 day EPG and provide services like MyFreeview. Quote
gemini7 Posted September 15, 2009 Posted September 15, 2009 (...)In germany we don't have MHEG-5, so we have to depend on your support to make it work for you. This is just to let you know that in fact there is MHEG-5 in Germany: STB manufacturer Technisat is beginning to offer MHEG-5 compatible receivers supporting a service called "TechniSat MultyText®". They even operate their own channel "TechniTipp" on 19.2E with MHEG-5 transmissions: See their press release here: IFA-Neuheit 2009: TechniSat MultyText® für interaktives Digitalfernsehen or here: New at the IFA 2009 show: TechniSat MultyText® for interactive digital television Quote
uglyned Posted September 15, 2009 Posted September 15, 2009 In the UK some channels have started sending out a 'remind me' button on trailers for programmes. The idea is if you want to watch the show that the trailer is advertising you press the green button and it gets added to your planner. This could be specific to Sky plus boxes but just in case it's a bit of generic code with just a show name and time in it I thought I'd mention it. Quote
gemini7 Posted September 15, 2009 Posted September 15, 2009 Because there is already a fully working way to do it: Transmit the EPG in the EIT like everybody else does it. Every DVB receiver can work with it out of the box. There is simply no sane reason to make a MHEG EPG. And there is no reason to write a complicated conversion just to undo (and support) the stupidity of some broadcasters in one country. How about the UK? They also don't have their EPG in the EIT (aside from NOW and NEXT), neither Sky nor Freesat. Maybe the reason is indeed that they don't want that any DVB receiver can work with it! Using MHEG they have full control of how the user experiences the EPG, which for most users is good as they can get along with anybody's receiver. Quote
ddichiera Posted January 14, 2010 Posted January 14, 2010 Just wondering how this is going, is there a beta or general release available yet? Quote
dvb-guenni Posted March 16, 2010 Posted March 16, 2010 Just wondering how this is going, is there a beta or general release available yet? I'm wondering too . Any news or release plans available ? Quote
mborkP Posted March 19, 2010 Posted March 19, 2010 Hi, are you guys still working on this project? I would be glad to help and send some streams for australian sat. provider. Please let me know. Thanks Quote
hackbart Posted March 22, 2010 Author Posted March 22, 2010 The good news is that it is quite likely that the DVBViewer will become Mheg5 support, but the bad thing is that we don't know when this will be done. I will keep you informed anyway.. Christian Quote
hackbart Posted May 7, 2010 Author Posted May 7, 2010 It has been a while since i had dropped a status report about Mheg5 here. Lars and I had spent a lot time to get the GPL based MHEG-DOTNET Project working with NZ and Chinese Mheg5 Applications, but two issues made us drop any further work on it. First of all the license forced us to do so, since GPL does not allow the usage by proprietary software like the DVBViewer, and second the code was "just" a port of FreeMheg which is in its current state also far away from complete. Anyway the good news is that we finally licensed a professional Mheg5 engine which is usually intended to work in regular STB's. This means that the DVBViewer will come with the most complete and fastest Mheg5 solution available on the market, within the near future. Christian Quote
