pruemmler Posted August 13, 2009 Posted August 13, 2009 My setup uses a 4DTV receiver to move the dish and change polarities. I have Cband and Ku band lnbs on the dish. I use a 22k switch to switch between the cband (22k tone off) and Ku lnb (22k tone on). Must I add two different satellites in transedit because the tone on and off is determined by the satellite? If so, can they be at the same orbital position or do I have the add say .1 degree to one of the positions. For exmple AMC 3 at 87.0 W is dual. Do I need one satellite AMC 3 cband at 87 W and one satellite AMC 3 Ku at 88 W. 1 Quote
Griga Posted August 13, 2009 Posted August 13, 2009 Must I add two different satellites in transedit because the tone on and off is determined by the satellite? The usual setup for European Ku band Universal LNBs is LOF1 = 9750, LOF2 = 10600, LOFSW = 11700 MHz. The 22 KHz signal is used for switching between the low and high Ku band (frequencies below and above LOFSWitch = 11700 MHz), from which you can see that 22 khz off/on is *not* determined by the satellite position. It varies according to the transponder frequency and LOFSW. TransEdit & DVBViewer assume the following: - if the transponder resp. channel frequency is below LOFSW the LOF shall be LOF1 and 22 khz shall be switched off - if the transponder resp. channel frequency is above LOFSW the LOF shall be LOF2 and 22 khz shall be switched on. DVBViewer & TransEdit don't store the LOF1 / LOF2 / LOFSW settings in the channel list resp. scan result data, but only the resulting LOF and 22 khz off/on (as you can see in the DVBViewer channel list editor), due to "historical" reasons: The TechniSat SkyStar2, which was the first and for some time the only supported DVB-S card, expects these parameters for tuning. However, BDA drivers want the LOF1, LOF2 and LOFSW values (which means, they make their own decision about the resulting LOF and 22 khz off/on - don't ask me why, MS design), so these values must be somehow re-created from the LOF and 22 khz information in the DVBViewer channel data. It is done in the following way: 22 khz off: - LOF1 = channel data LOF - LOF2 = 10600 MHz (default value) - LOFSW = a frequency above the transponder frequency 22 khz on: - LOF1 = 9750 MHz (default value) - LOF2 = channel data LOF - LOFSW = a frequency below the transponder frequency If the driver works as expected, it compares LOFSW and the transponder frequency, sets 22 khz off/on accordingly, selects LOF1 or LOF2 accordingly, and ignores the other LOF value, thus doing exactly what's in the DVBViewer channel list. But who can tell with drivers... I have no practical experience with your kind of setup, but from theory I' d say with LOF1 = 5150 LOF2 = your Ku band LOF LOFSW = some frequency between the Ku band and C band transponder frequencies merging C band and Ku band into a single transponder list should work, provided the DVB device driver doesn't get confused by it. Try... Quote
pruemmler Posted August 14, 2009 Author Posted August 14, 2009 I have no practical experience with your kind of setup, but from theory I' d say with LOF1 = 5150 LOF2 = your Ku band LOF LOFSW = some frequency between the Ku band and C band transponder frequencies merging C band and Ku band into a single transponder list should work, provided the DVB device driver doesn't get confused by it. Try... That's what I call a very good explanation. It worked. I did the following: LOF1 = 5150 LOF2 = 10750 LOFSW = 10000 Thank you! pruemmler Quote
