support AES3?
svingen
Hello
i have dvb-c card and running windows 7 but i do have problem on 1 HD channel.
here is info from mediainfo
General
Complete name : C:\Users\Public\Videos\08-14_23-09-47_Discovery HD_Ultimate Survival.ts
Format : MPEG-TS
File size : 117 MiB
Duration : 46s 934ms
Overall bit rate : 20.9 Mbps
Video
Menu ID : 3111 (0xC27)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Bit rate mode : Variable
Bit rate : 19.4 Mbps
Nominal bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.374
Stream size : 109 MiB (93%)
Audio
Format : PCM
Format profile : AES3
Duration : 46s 926ms
Bit rate : 91.7 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 2 292 Hz
Resolution : 16 bits
Video delay : -217ms
Stream size : 523 KiB (0%)
Language : English
if i record it and watch it using VLC i get sound but using DVBViewer i don`t get any sound.
think this is a "new" codec due it don`t work on my dreambox 800HD either ;)
it is only this channel but kind of miss this channel,will it be support on AES3?
did not find any direck show filter either that support this.
Quite difficult. Please read what Donald Graft (a video/audio specialist) has written about it:
http://neuron2.net/board/viewtopic.php?p=8...67851a48199b57d
The specifications that are necessary for supporting it are not available for free. Additionally it seems to be difficult to find an AES3 DirectShow decoder. Google delivered some results that are pointing to Elecard/MainConcept, but that are commercial decoders that have to be purchased.
A bit expensive for just one cable channel, I'd say. However, I'll keep an eye on it... if there is a way to implement it with justifiable efforts I'll try.
