Oliver Irsai Posted August 23, 2009 Posted August 23, 2009 Hello! I know it is an old story... but how can I get DVBViewer to start in HTPC mode? (in other words I want the HTPC OSD screen to pop-up automatically afters start-up. So that I do not have a black screen after start and I do not have to press esc or any other key to have it.) (Please do not tell me, that I can set it up in the General options menu, because this option (HTPC-mode) is missing. I use DVBViewer 4.2.1) Thank You very much in advance! Oliver Quote
Devastation Posted August 23, 2009 Posted August 23, 2009 Start DVBViewer with parameter -x2110 Other OSD Windows have other codes. You find them in the actions.ini in your DVBV Installation folder. Quote
Oliver Irsai Posted August 23, 2009 Author Posted August 23, 2009 Thanks I will check it out! Besides, what can be the reason for the the missing option in the setup? Quote
Devastation Posted August 23, 2009 Posted August 23, 2009 (edited) Missing? Is/was there ever such an option? Edited August 23, 2009 by Devastation Quote
Oliver Irsai Posted August 23, 2009 Author Posted August 23, 2009 Check it out: http://www.DVBViewer.com/en/index.php?page...er=g⊂=g1 Quote
Devastation Posted August 23, 2009 Posted August 23, 2009 you mean this?: HTPC-Mode changes the behaviour of the DVBViewer. Window mode is the standard setting for normal mouse control, HTPC mode starts in full-screen/OSD mode and requires a remote control. This is not to set in the options but to direct edit in the setup.xml. You find infos about the HTPC-Mode in the tweaks.txt that is in your DVBViewer Installation folder. But this ist not what you want to have. This is somewhate a save-mode. You can set with these that no one can make input other than channelchange for example. You better leave this Quote
Oliver Irsai Posted August 30, 2009 Author Posted August 30, 2009 Start DVBViewer with parameter -x2110 Other OSD Windows have other codes. You find them in the actions.ini in your DVBV Installation folder. I have tried it out, and it does not work... DVBViewer starts, but with the same old black screen (I do not have any channels set up), so I still have to press ESC to have the OSD come up. Any ideas? + I have another question: How can I make DVBViewer to "remember" the last position of the cursor and at the next start have it already there? (example: I am in the My Videos menu in some folder, then I quit. At the next start I would like to be instantly at that folder within the My Videos menu.) Is it possible? Thanks again! Quote
Devastation Posted August 30, 2009 Posted August 30, 2009 here it works without problems (XP, overlay and Vista overlay) Quote
Oliver Irsai Posted August 31, 2009 Author Posted August 31, 2009 Strange.. I have tried it on Vista and XP too, on two different computers but it still does not function. Just to make sure, it goes like from the command line: dvbviwer.exe -x2110 Am I right? + I have another question: How can I make DVBViewer to "remember" the last position of the cursor and at the next start have it already there? (example: I am in the My Videos menu in some folder, then I quit. At the next start I would like to be instantly at that folder within the My Videos menu.) Is it possible? Quote
Devastation Posted September 1, 2009 Posted September 1, 2009 dvbviwer.exe -x2110 more like "C:\Program Files\DVBViewer\DVBViewer.exe" -x2110 for the parameter in a shortcut you probably need the " How can I make DVBViewer to "remember" the last position of the cursor I think thats not possible. But I'm not sure. Quote
