DVBViewer video periodic freeze
vizz
Hi.
I have this problem DVBViewer (newest version) where the reception picture freezes slightly 1 to 2 times every 1 or 2 minutes.
I have the same problem on 2 different machines, a Quad Core with Windows 7 (Nvidia GTS250 Gfxcard) and an AMD 64 3200 (Nvidia 8800GT Gfxcard) with Windows XP.
I have tried to install PowerDVD9 to try another MPEG2 decoder codec, but it doesnt seem to remove the problem.
I dont know if this problem is caused by the software rendering codec, but is it possible to install another beside the standard (any suggenstions ?)
I do not have the problem with TerraTec's own software for the H7 - the software is slow but it doesnt freeze the tv signal.
I would be glad for some help.
Best Regards
Peter
Hi.
Best Regards
Peter
If I enable Timeshift the problem seem to dissapear - is it normal to enable this feature ?
The problem still occurs - but perhaps a little less, any suggestions ?
  • 4 weeks later...
I'm struggeling with a similar problem. Getting discontinuities, have a Terratec Cinergy C tuner...
Skystar HD2 too
Probably a Latency Problem,
Google for DPC Latency Checker.
I had similar problems and identified a WLAN driver as culprit. After updating it the problem disappeared.
I had a similar problem too, but someone recommended that I go to the DVBfilter settings and change Latency to 2000, and Max Queued TV/Radio to 0 and 0. Problem solved. It did impact the channel change speed a bit, thoigh, but if it works, you can try and tweak the settings to minimize the delay.
