helio58 Posted August 30, 2009 Posted August 30, 2009 Hi, I´m using DVBViewer 4.2.1 Install Recording services (svc_setup_1.5.0.31.exe). In the computer that is running recording services I can reach the recording services webpage. But from another computer in the LAN I cant . I know its a firewall problem , but could samebody please let me know how to make it accessiblle in the LAN? Regrads Helio
Devastation Posted August 30, 2009 Posted August 30, 2009 I know its a firewall problem Sure? You have deaktivated the firewall and than all is working fine? There can also the IP in the RecService be set to 127.0.0.1 here Or maybe the port is used by another prog. For the firewall: there sould somewhere be a log that will show what the firewall has blocked. There you can find out what ports you must enable. See firewall manual for details.
helio58 Posted August 30, 2009 Author Posted August 30, 2009 (edited) Sure? You have deaktivated the firewall and than all is working fine? Thats right when I turn of the localnetwork firewall (Incomming connections) then the recording webpage show up. I will try to fiind the log of the firewall. Helio Edited August 30, 2009 by helio58
kdk_warhead Posted March 28, 2010 Posted March 28, 2010 Hi! I'm new to DVBViewer but it works for me to connect to "recording services webpage" from another computer. I had to open the "web/UPnP" port in the firewall on the computer with the recording service (Windows XP). Somewhat old thread but some might find it useful.
