israb Posted September 6, 2009 Posted September 6, 2009 Can we have fixed numbering for channels in the favourite list? Now, if I add a channel to the list, all the channels below it get a new number, it is very confusing. It would be better if we can decide that a certain channel is "100" and it always stays that way. Alternatively: add numbers to folders in the favourite list (for example, "Sports" is "5" and the fav list opens in the folder to choose a channel. Thanks! Quote
patti Posted October 12, 2009 Posted October 12, 2009 If only the OSD would show favourite numbers when switching channels.... The favourite folder list already works with the folder numbering system. If you have a list of favourite folders on the screen you can use 0 to select the first folder, 1 to select second etc. Or do you mean setting a fixed number for different folders? That would contradict with the normal numbering system of DVBV. Quote
