System standby
business101
im having a small problem with the recording service
when the service is running i cant hibernate or standby the HTPC.
when i stop the service the problem disapears.
my pc is xp with a floppydtv tuner
DVBViewer V4.2.1
recording service 1.5.0.31 Beta
im sure its a simple setting i have missed but i cant seem to find it. :)
I have been reading up about the problem, and I found that this problem could relate to the veto problem with xp
Is there any way to solve this in upcoming versions?
DVBViewer V4.2.1
im sure its a simple setting i have missed but i cant seem to find it. :D
i have partly solved the problem ;)
i had scheduled task that updated the epg
when i deleted it the problem disappeared.
Of course you can't sleep your PC during a "recording". And from the recording-service point of view the "EPG Update Timer" is an ordinary recording. If I understood that timer correctly, you can just shedule a "internal task timer" with task "EPGUpdate Start" for a minute. Then the service will block the PC only for this minute but do the EPG Update completely anyway. But if you go into standby during the EPGUpdate it's interrupted of course and I think it's not restarted automatically on wake up.
nope this is not the case
i had the reoccurring epgupdate with xepg to run each morning at 06.30 to 07.00, but the machine would not hibernate or standby all day.
im aware that i wont shut down during a recording. thank god for that
i had to delete this epgupdate taks to get things in order
when the RECORDING service is running i cant hibernate or standby the HTPC.
Edited by business101
