Sydney Posted October 11, 2009 Posted October 11, 2009 Basically DVBV does not seem to like changing channel to record while minimised with A/V disabled, I dont think it is a problem if I dont disable A/V on minimise, but that is not practical. If I set 2 recordings on different frequencies that do not overlap, then minimise DVBV on the 1st frequency, the 1st program will record fine, then when it comes to the next recording, the ts file appears but stays at 0 bytes. It works fine if I record 2 different channels on the same frequency. I am using the video recorder plugin, but it does the same with the built in record service. I'm using version 4.2.1, running on windows 7 x64, and I'm sure it did something similar with vista x64. My card is a compro videomate s350. Any ideas? Thanks Quote
