Recording service
Per Raebild
I have just installed recording service 1.5.0.31 - but missing EPG info - is there any more configuration needed than checking the field receiving EPG data?
Is there existing any "usermanual" for recording service?
Thanks in advance
Per
If you setup the hardware correctly in the recording service options and enabled the EPG Update option, it should start to collect the EPG shortly after starting. This might take some time, depending on the size of your channel list.
Some explanations can be found in the wiki
I have followed the guideline for the installation, but still not having any EPG info available.
I saw the instruction You send me, after i have studied this im not sure i fully understand the settings in dbvviewer, especially
the creating unicast devices i have some problems with.
is this point important if the service is installed at the same pc as the card and the dbvviewer?
When i check the connection under DVBViewer Recording Service Settings it seems to be correct, however nothing happends with EPG info.
Any hint you can suggest me to try out?
BR per
Edited by Per Raebild
...not having any EPG info available.
followed the complete guide or maybe missed some points :)
one of the most important!
Let us check your configuration:
Klick the link and follow the instructions for posting support.zip
Edited by Devastation
I probably missing some points, wel... to be honest not all points i understand fully - however i will keep fighting until it works :)
Im using 2 TechnoTrend Budget 1501 DVBC cards - channels and EPG works directly in DVBViewer without any problems.
Attached find the suuport.zip file
Hope You can give me a hint...
BR Per
You should not use UserMode=0 pleas change to UserMode=2.
Changes to usermode=2 - dosnt make any difference, tried to remove install and again install - now it crash after installation, and the service cant be installed.
Any idea why how to avoid it crashes? Br Per
Pleas post a new support.zip because in the last one where many files missing.
I gave up with this installation - however i will try again, but probably use win 7 which i just bought.
I have studied the installation manual of recording service, and have some question i feel unsure about.
In the manual there is a image showing Unicast Network Device - if i install Recording service at same computer as the DVBViewer/server, should Autodiscover still show the Server available?
The image shows under DVB Conrol Server an IP adress fex 192.168.178.24 and Serverport 4012, where does this ip have its reference to/from? DVB Unicast Device shows 192.168.178.24 but serverport 2345 - where does the ip+serverport have its reference to/from?
Yes
The static IP is the IP from your PC in your local network. If you use the DVBViewer an Recording Service only on one PC you can use 127.0.0.1 as well.
An there are three different ports:
Web interface (80) in Recording Service:
http://en.DVBViewer.tv/wiki/Options_Service_-_Web/UPnP#Port
and DVBViewer > Options > Recording Service
Control Server (4022) in Recording Service:
http://en.DVBViewer.tv/wiki/Options_Service_-_DVBServer#Port
and DVBViewer > Options > Hardware > Unicast Network Device
Streaming Server (3456) in Recording Service:
http://en.DVBViewer.tv/wiki/Options_Servic...VBServer#Port_2
Thanks for the help - i finally got it working now on Windows 7, i love this application - fantastic tool for TV nuts like me :)
