Could not record one of the DTV HD channel
SatDream
Good day, I have found one problem of could not record one particular DTV HD channel, (when record is pressed, the red record button flash for about 1 sec and stop.),but I could record all other HD and SD channels.
But if I convert back to version 4.1.1.0 then there is no problem. for recording the same DTV HD channel, all are free channels.
I have two PC with different DTV card (DMB-TH) but the same problem with the same DTV HD channel could not be recorded.
So I have to revert back to DVBViewer pro 4.1.1.0 version for the moment.
Could not record the following channel:
HDaTV
Network ID 32767
Frequency 602000 MHz
Brandwidth 8 Mhz
Stream ID 2
VIDEO PID(V) 121
AUDIO PID(A) 122
TELETEX PID 0
SERVICE PID(S) 12
VIDEO H.264
AUDIO AC3
PMT PID 120
PCR PID 121
But could record the following HD and all other channels.
High Definition Jade
Network ID 32766
Frequency 586000
Brandwidth 8 Mhz
Stream ID 1
VIDEO PID(V) 851
AUDIO PID(A) 852
TELETEX PID 0
SERVICE PID(S) 85
VIDEO H.264
AUDIO AC3
PMT PID 850
PCR PID 851
TV card:Mygica 8550 dual tuner PCI (DMB-TH)(without analog capture)
Driver:Conexant 1.2.505.0
Mainboard: Gigabyte P43 ES3G, Intel ICH10R SATA AHCI, Intel 82801 PCI bridge
Display: ATI Radon HD4550, Driver: 8.632-090702a-084680C-ATI ,Catalyst™ 09.7 ,Catalyst™ Control Center 2009.0714.2132.36830
CPU Intel E7400
OS: Win XP pro SP2
Thanks.
  • 4 months later...
In another Chinese forum for DVBViewer, I have read how to solve this problem, as the file name in the EPG is not properly decoded in the same working language of my computer, (I am using CHS) for the channel in view. Hence the prgrom could not be recorded, if I e delete the last "event" setting in the recording file name rule, then the program could be recorded. I am now using the latest version that could record every channel without problem.
I also suggest that in the file name recorded, the first file name should begin with 00, otherwise it is always placed in the last file in the Windows explorer, where the first file recorded should come before the file 01.
