bogger Posted October 30, 2009 Posted October 30, 2009 I want to record programs either directly in avi format with mp3 (eg lame) audio, or in a higher format with transcoding later on. The reason is I do most of my viewing in an archos video device and that is the standard it takes. I'm new to DVBViewer and getting a bit lost in all the settings. Could someone guide me on how to that. thanks Quote
Lars_MQ Posted October 30, 2009 Posted October 30, 2009 Record as Transport Stream (TS) and then transcode it. The Viewer won't do that for you. Quote
bogger Posted October 30, 2009 Author Posted October 30, 2009 thanks. but where to I set up the transcode settings and where do I run the transcoder from? Can it run automatically after the ts is recoreded. apologies if its in the manual but it will not open properly for me. (I get the contents but the pages are blank?) Quote
Griga Posted October 30, 2009 Posted October 30, 2009 DVBViewer can't do that for you. Transcoding to AVI/MP3 is not supported. You will have to use other software. Quote
bogger Posted October 30, 2009 Author Posted October 30, 2009 such as?. which transcoder can handle .ts files?. Or can I record in .mpg files instead? Quote
Griga Posted October 30, 2009 Posted October 30, 2009 Well, there is a search engine named Google... maybe you've already heard of it. Use "cconvert TS to AVI" or "convert MPG to AVI" keywords. Quote
Lakeuk Posted October 31, 2009 Posted October 31, 2009 http://www.videohelp.com is the oracle for transcoding questions Quote
