All schedulel recordings becom inactive
McenterFreak
Hello
Somtimes some or all scheduled recordings suddenly become inactive (red button). Then i need to click on the red button to activate them again, one by one. Then all the recordings now appears as conflicting (the are now red). If i then delete one of them, everything then seems to be okay
I am using Recordingservice Beta 1.5.0.55, and i use the web interface to schedule recordings
No ideas at all?
I am afraid to trust the application, if I can't be shure that schedueled recording are executed
What is the idea to post problems, if nowbody cares?
It could be nice if one of the developers wrote that he is looking at the problem
I'm not a developer, but I'm sure that you have to (as you can read on top of this tread) Always follow these instructions. Otherwise no one can - or wants - to help you!
ATM it seems that only you are suffering this problem, so it must probably reside only on your PC/configuration; therefore the support.zip is really badly needed to try to help you...
o:)
Sorry, but i thougt that the Supporttool was only for DVBViewer, not for Recording Service, so here it is:
