Can't access Webinterface from remote computer
First of all thanks for this wonderfull Recording Service, I had some problems making it work [removed] but now it's fantastic, very very handy.
I have it working very well in the computer that hosts DVBViewer and recording service, but when I try to access the webinterface from another computer in the network I can't. What I do is putting in the web browser the ip of the host computer plus ":" and then the port --> 192.168.1.xx:8060
Am I doing something wrong? I should install Recording service and DVBViewer in all the computers that access to the host?
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.info/forum/index.php?act=boardrules
No, that's not necessary.
The program "DVBVservice.exe" should be added to the exceptions of the Windows firewall, otherwise a access from another PC is not possible.
Regards
Prinz
It is allready added, I don't know what is the problem then. I am using Windows 7 x64 if that matters. I'm going to check though because what I added is called DVBServer if I remmember correctly.
Thank you
Thank you
Have you tried to disable the FireWall in both machines?
If that help, then you know for sure its a firewall problem
Can you access it from the PC where Recording Service is installed?
It is also important to use Static IP on the server side
Problem solved I enabled exception in firewall of DVBServer but not of DVBVservice, it works now flawlessly. Thanks for the help.
I can access the web interface, it asks username/password but when I login I just get "404 Not Found" error?
Add to previous: Running W7 x64 Ultimate and on another PC running the very same windows RecService is working fine and I Web Interface works.
I've tried to uninstall RecServ several times (also DVBViewer), turned off windows firewall, nothing helps.
OT: Where's the edit message button?
Ok, found the reason but not the solution:
I accidentally exctracted the beta .60 zip to a false folder and ran the exe there and even though I reinstalled the service to DVBViewer folder, it still tries to use that false folder as a root. If I copy the "SVCweb" folder to from DVBViewer folder to that false folder, then the web interface opens.
So, where can I find Recorder Service registry entries to delete to get this fixed?
