dvbviewer r3 opening problem
coolworm
when i try to open DVBViewer does`n to enything! i have to reinstal the DVBViewer again and then its works.
when i make restart its doing the same.
why??
thanks
Try to delete the Setup.ini file instead of re-installing - not as a solution, just for diagnostics.
i delete setup.ini, i reinstall DVBViewer but its the same!;) any ideas?
give us mor information about your system.
DirectX, which system you use, which version of DVBViewer you use, which decoder you have onboard .....
i have directx 9, pentium 4 1,8ghz,sound blaster live, ati radeon 9200,skystar 2 and its fresh formated with windows xp pro sp1. anything else? ;)
Hmmm, we had a member here in the board which had problems with soundblaster and SS2.
Which driver version of the SkyStar you installed? 4.22, 4.28 or newer? Have you installed DirectX9b? In 9 and 9a was a bug. Have you IRQ - conflict ore ohter hardware problems? Which Board (chipset) you are using?
Is the DVBViewerTE running? Is TV4PC running? If you have a look in the taskmanager , can you see there a process (not a application) which called DVBViewer.exe? Which mpg2 - Decoder (DVD Software) you have onboard?
I know this are a lot of questions. But all this can give us a hint to solve the problem.
Steffen
