entrecour Posted December 19, 2009 Share Posted December 19, 2009 I have been having tuning problems with BBC HD in particular for longer than I can remember. Attached is my support.zip - this time DVBViewer stopped responding when I tried to tune BBC HD, but most often I get a pixelated green screen. I tuned 3 other HD channels successfully before trying BBC HD - I am not sure if this is visble in the log. I'll try and generate a new support log with after a green screen. Quote Link to comment
entrecour Posted December 21, 2009 Author Share Posted December 21, 2009 A new support zip after green screen with TV4 HD. Quote Link to comment
Griga Posted December 23, 2009 Share Posted December 23, 2009 Most likely caused by the H.264 decoder, maybe in combination with hardware acceleration and/or video rendering. Try Options -> DirectX -> TV/Radio Pre-Format Detection -> Video or a different H.264 decoder. Quote Link to comment
Lars_MQ Posted December 23, 2009 Share Posted December 23, 2009 Use the cyberlink decoder für Video instead of nvidia and coreavc. and set to "0" or remove <entry name="EVRVideoprocessor">1</entry> from the setup.xml [MPEG] section. Don't touch the autodetect stuff, leave it off. Quote Link to comment
