Syrck Posted December 20, 2009 Posted December 20, 2009 Hello, I I have been reading about how moving rotor with DVBViewer 4.2.1.0 but I don't find the solution. Anybody know if is possible use angular position ( usuals) for moving rotor with TechniSat SkyStar2 ? Drivers versión : 4.5.0 i read this in the TransEdit manual : " There are devices (particularly TechniSat SkyStar2) that provide a DiSEqC 1.1/1.2 interface, but the driver blocks according commands in order to avoid damage caused by the high power consumption of motorized dishes. " and : "The Positioner item in the TransEdit Main Menu opens the Positioner Console. It is only availabe if a DiSEqC 1.2 capable device is listed under „Settings/ Hardware“. Then is imposible use my devise don't support DiSEqC 1.2 ? is problem of drivers ? i have other maners to do it ? Best regards, Syrck Quote
Griga Posted December 20, 2009 Posted December 20, 2009 Then is imposible use my devise don't support DiSEqC 1.2 ? That's correct. Though the SkyStar2 resp. the driver is able to send DiSEqC 1.2 commands, the hardware is not suitable for driving a motor. It may damage the SkyStar2 or even the mainboard. That's why DVBViewer and TransEdit don't support it. Quote
patrona Posted December 22, 2009 Posted December 22, 2009 It is possible to use motor with Skystar 2, I was using it more than 4 years without any problem. Last year I used Skystar2 rev. 2.6D and motor SG-2100A Moteck with DVBViewer, moving was done by MiBi DiSEqC plugin. Commands were send to the plugin from DVBViewer channelchange.vbs script so everything worked automatically. Only when I wanted use TransEdit I had to move to relevant satellite position by DVBViewer firstly or move directly by the MiBI plugin - TransEdit has disabled positioner option... Quote
