patti Posted December 29, 2009 Posted December 29, 2009 Hello, is is possible to have two instances of recording service (latest beta version) running at the same time? I have two different installation folders both with service files and used windows command sc create dvbv_recsvc2 binpath= <path to second dvbservice.exe> and have succesfully installed a second DVBVRecorder service into windows XP. It just won't start so my question is am I trying the impossible here or can two instances exist side by side? I have disabled the first installer created service but even that does not make my second service install run. My guess is that both installations share a common SID or something similar which prevents the second service from running or I need to install the service in a specific way but I can't find anything to confirm this. Any help please? thanks in advance, patti
Devastation Posted December 30, 2009 Posted December 30, 2009 AfaIk this is not possible. DVBV can have 2 instances but not the RecordingService.
Lars_MQ Posted December 30, 2009 Posted December 30, 2009 The recording service is a windows service and there only can be one instance. it's impossible to run 2 instances of it.
patti Posted December 30, 2009 Author Posted December 30, 2009 (edited) Hello again I have tested this a bit further. It is true that it is not possible to install two instances of the service with the provided installer. But it is possible to run two DVBVService.exe at the same time as normal applications and have two servers for DVBViewer to connect to. This provides me with what I need, thank you for your time patti ̈́ Edited December 30, 2009 by patti
