jdou Posted January 1, 2010 Posted January 1, 2010 Hi, I have installed the DBV view setup on hotbird. I have a good reception. every time I try to launch the Viewer, an icon is seen on the taskbar but the programme shows that it is open but there is nothing seen. I have been using DVBviewerand other programs for some time but had to instal everything again on a new hard disk and gt this problem. Any help would be appreciated. Quote
hdv Posted January 1, 2010 Posted January 1, 2010 had you used dual monitor or so? http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
jdou Posted January 2, 2010 Author Posted January 2, 2010 no I only have it on a single pc with one monitor although the pc is networked with other pc but it has always been like that. Quote
Gioxy Posted January 2, 2010 Posted January 2, 2010 (edited) there is nothing seenA cause can be that the main DVBViewer window opens outside you monitor; to reset it's coordinates you have to:- close DVBViewer - open "Help / Configuration folder" - open "setup.xml" file with a text editor (eg Notepad) - look for the section "Display"; here are the default values of X & Y coordinates and the Width & Height of the DVBViewer window <section name="Display"> <entry name="X">0</entry> <entry name="Y">0</entry> <entry name="W">730</entry> <entry name="H">670</entry> - modify the four values as suggested above and save the file- start DVBViewer Edited January 2, 2010 by Gioxy Quote
jdou Posted January 2, 2010 Author Posted January 2, 2010 sorry but I tried to find the said file or folders but couldn't find them anywhere. Can youy please indicate steps how I coudl do so please? Quote
Gioxy Posted January 3, 2010 Posted January 3, 2010 Sorry, you are right, I wrote a nonsense... Substitute the first 2 instruction above with these: - open DVBViewer - open the menu named "Help" - click on the voice "Configuration folder" (this step open the right DVBViewer configuration folder, there can be more than one) - when the configuration folder open up, you have to close DVBViewer, otherwise the modfication you'll make to the file "setup.xml" wll not be mantained... Quote
