Permanent "No Render" option
maddin
the new version is able to stop rendering for recording time. It is possible to bring this option to Mainprogram ?
In this case it will possible to create an Recording PC with old (slow) hardware, which can be build without active cooling.
Hope this will be a "peanut" for you ;)
Martin
Guest Oliver
You can disable A/V-rendering in the recorder-control window at "AV control".
Bye, Oliver
Hi Oliver,
i understood this, that rendering is only disabled during recording ?
I want to disable rendering permanently!
Mfg Martin
Edited by maddin
No problem... just use the graph selector -> disable AV
Guest Oliver
Yes. But the AV-control disabled the rendering until you switch channels. That function is independent of the "no playback while recording" checkbox.
Bye, Oliver
Guest DAvenger
Christian could just add "Null renderer" option under "Renderers selection". I've seen this in MPC.
Guest Oliver
Hm, that's not very handy. I'd prefer a button that calls the "disable AV-rendering" function of the recorder-control window, with a null renderer you'd have to change the graph.
Bye, Oliver
Bye, Oliver
If this will disable rendering permanently, it will be OK.
Remember, the target is recording only PC, this PC will not use rendering at any time.
But better (for other users) will be a function who enable/disable rendering from mainwindow.
Edited by maddin
As Derrick said... the solution is already there - go to the Service Center, download the GraphSelector Plugin and read the ReadMe. Use it or ignore it :)
In the moment I still have the problem that after max. 12 hours DVBViewer freezes. I am already using the GraphSelector plugin, so selecting NO AV would be very easy; but how can I determine if DVBViewer is still running fine - and ready ro record if I don´t have picture and sound?
Open the recorder control window that displays the stats - last but one icon at the right.
@Derrick
It's working fine !!!
