Free MPG2 codec ! YMPEG
Klausing
YMPEG
YMPEG is a first Freeware MPEG Codec which can integrate itself with Windows and offers seamless encoding from your favorite application. YMPEG is Windows AVI codec (VFW). After installation, it becomes part of Windows so that it can be used by any application which uses Windows Compression Manager (like VirtualDub, Adobe Premiere, AE, Vegas etc.). It can also be use for real-time MPEG encoding.
YMPEG Supports:
- MPEG-1, MPEG-2, VCD, SVCD (ISO/IEC 13818, 11172), DVD, KVCD (non-standard), CVD
- Audio Layer 1, 2
- PAL/NTSC
- Variable and Constant Bit Rates and lot more...
YMPEG Advantages:
- Direct encoding from your favorite applications without any intermediate file or frame servers. This is most simplest way to create MPEG files.
- YMPEG is only MPEG codec which integrates with OS (as far as I know).
- Real-time Encoding
- Highest Applications Compatibility
- Very good Quality
- Fast
- Rich set of options.
- Very handy in converting to MPEG from other formats
- SDK to integrate with your own software
Changes from YMPEG 0.6.13 Alpha to YMPEG 0.6.14 Alpha:
This version was supposed to have new rate control algorithm. However, probably it will be included later as few more changes are required. So this is a bug fx version.
YMPEG SDK Lite is available with this version.
cheers
Steffen
Already postet here :)
Didi
sorry :)
No problem .... nice 2 be the 1st :)
Hmmm ... ... ... wait i will overhaul you without to catch up .....
