UniStreaming.dll listed as virus by PrevX
dvbrewer
Just did a scan this came up, also now when I launch DVBViewer it takes 10 seconds to open and MSMPEng.exe (MS Security Essentals/Defender) goes crazy to about 50% CPU usage- anyone else having similar problems?
Edited by dvbrewer
UniStreaming.dll
Is not part of the DVBViewer.
oh, this is a really old "plugin" for the popcorn hour. just delete it. I'm absolutly sure it is in itself no virus, it has been around for several years, so you can write it off as a false positive. :unsure:
Hmm, it is in DVBViewer>Plugins folder and turns up on a board search :unsure: ?
It's part of the "Web Interface 1.5" from the member area.
For what do you still need it?
Let me guess:
Prevx list it as: "Medium Risk Malware"?
But don't panic, it was testet before; a very small amount of virus scanners may list it just as a "suspicous" file: o:)
http://www.virustotal.com/de/analisis/89a1...4769-1242894465
http://www.virustotal.com/de/analisis/89a1...4769-1264634599
oh, this is a really old "plugin" for the popcorn hour. just delete it. I'm absolutly sure it is in itself no virus, it has been around for several years, so you can write it off as a false positive. :)
Thanks, I think PrevX is a little too eager for me to make a purchase o:) .
Let me guess:
Looks like a false positive anyway, still doesn't explain the slow startup and Windows Security Essentials/Defender activity going crazy though unless they think the file is bad too :unsure: .
Just to update, this was a problem with MS Security Essentials, I swapped it for Kaspersky and the problem has gone (w00t) .
