RW_ Posted February 3, 2010 Posted February 3, 2010 Hi I lost the picture in DVBViewer. I tried to use VLC to open my PROF 7301 for 4:2:2 viewing ( it did not recognize the card )and went back to DVBViewer I have good Signal Quality but no picture. Any help? Thanks RW Quote
McenterFreak Posted February 3, 2010 Posted February 3, 2010 You need to give more information. First off all: support.zip. The people that can help you (i can't) will newer answer you, before they have this file Quote
RW_ Posted February 4, 2010 Author Posted February 4, 2010 (edited) You need to give more information. First off all: support.zip. The people that can help you (i can't) will newer answer you, before they have this file Hi McenterFreak What is: support.zip, and do I need to install it? EDIT OK I found the: support.zip downloaded it but is wantts to be opened in DVB Dream . How do you open it in DVB Dream? Thanks RW Edited February 4, 2010 by RW_ Quote
McenterFreak Posted February 4, 2010 Posted February 4, 2010 You need to make a support.zip as described here Quote
RW_ Posted February 4, 2010 Author Posted February 4, 2010 (edited) I have installed the support.zip in DVBViewer file it opens and has my configuration information in it. Where do I find the return support.zip to post here??? Edited February 4, 2010 by RW_ Quote
RW_ Posted February 4, 2010 Author Posted February 4, 2010 (edited) ? Edited February 4, 2010 by RW_ Quote
RW_ Posted February 5, 2010 Author Posted February 5, 2010 (edited) I have gotten the Support Tool to work and have gotten it to give a URL with a path back to a C:/ File not a Zip File. how do I get the Zip File?????? Edited February 5, 2010 by RW_ Quote
McenterFreak Posted February 5, 2010 Posted February 5, 2010 ? Take it easy now, i am not a computer, i also have a social live, like WATCHING TV Downlod the supporttool Copy it to c:\program Files\DVBViewer (or what your DVBViewer folder is named) Run it Now you have a file, support.zip in your configuration folder (configuration folder is the folder you find when you choose about>configuration folder ) Quote
