HomerDK Posted February 5, 2010 Posted February 5, 2010 Hi. Just purchased DVBViewer and it's running fine. But on some channels there is no audio. Im using it with a Hauppauge Nova-T-TD-Stick. Do I need some plugin to get audio on the other channels? Thx Quote
desweil Posted February 5, 2010 Posted February 5, 2010 Try FFDSHOW(tryouts) or AC3Filter as Audio codecs. This will most likely solve your problems. Quote
Tjod Posted February 5, 2010 Posted February 5, 2010 AC3Filter for MPEG2 and AC3 audio (http://ac3filter.net/) And for AAC audio libfaad2 Wrapper Filter http://www.DVBViewer.info/forum/index.php?showtopic=23347 Quote
HomerDK Posted February 5, 2010 Author Posted February 5, 2010 Thx But where do I find the libfaad2.dll to store in the same directory as Libfaad2Wrapper.ax ?? The installation step 3 says: Store the file libfaad2.dll (see above) in the same directory as Libfaad2Wrapper.ax but I can't find that dll file. Quote
HomerDK Posted February 5, 2010 Author Posted February 5, 2010 (edited) Here are some screenshots of errors. Seems that the channels with no sound are the one with AAC, the others with sound are ordinary Stereo. But no problem with AAC sound in Windows Media Center. Running on Windows 7 Ultimate Edited February 5, 2010 by HomerDK Quote
HomerDK Posted February 5, 2010 Author Posted February 5, 2010 Ok. Never mind, I was just blind as a bat. Now all works, I forgot to download the The_KMPlayer_1435 to get the dll file. Thx. :-) Quote
McenterFreak Posted February 5, 2010 Posted February 5, 2010 (edited) Here are some screenshots of errors.Seems that the channels with no sound are the one with AAC, the others with sound are ordinary Stereo. But no problem with AAC sound in Windows Media Center. Running on Windows 7 Ultimate You did not have to do all that. MS decoders, build into win 7, have all you need: AC3,H.264, HE-ACC etc. Edited February 6, 2010 by Griga Useless images removed Quote
Griga Posted February 6, 2010 Posted February 6, 2010 You did not have to do all that. MS decoders, build into win 7, have all you need: AC3,H.264, HE-ACC etc. Wrong. He had to. DVBViewer Pro 4.2.1 doesn't know the new media subtype GUIDs introduced by MS for AAC. It requires at least DVBViewer Filter 3.5 (previous versions don't connect to the MS AAC decoder) and maybe DVBViewer Pro Beta, where the MS AAC decoder is selectable in the options. Quote
McenterFreak Posted February 6, 2010 Posted February 6, 2010 Wrong. He had to. DVBViewer Pro 4.2.1 doesn't know the new media subtype GUIDs introduced by MS for AAC. It requires at least DVBViewer Filter 3.5 (previous versions don't connect to the MS AAC decoder) and maybe DVBViewer Pro Beta, where the MS AAC decoder is selectable in the options. I was presuming he was using the latest Beta, and the latest DVBViewer filter. Quote
Griga Posted February 6, 2010 Posted February 6, 2010 Just purchased DVBViewer and it's running fine. Someone who just purchased DVBViewer will most likely use a DVBViewer Pro 4.2.1 installation. Quote
McenterFreak Posted February 6, 2010 Posted February 6, 2010 Someone who just purchased DVBViewer will most likely use a DVBViewer Pro 4.2.1 installation. Your right. When will there be a new "non beta" version? Quote
HomerDK Posted February 6, 2010 Author Posted February 6, 2010 (edited) Hehe yup. I'm still a noob with DVBViewer. I have another question, when playing recorded files with AAC audio on Windows Media Player or on my WDTV media player I don't have any sound out, video is ok. No problem when playing the file on DVBViewer or VLC or channels with normal audio. Any suggestion on how I could get the audio playing on my WDTV? Usually it's able to play everything. Thx Edited February 6, 2010 by HomerDK Quote
