reesthil Posted May 2, 2004 Share Posted May 2, 2004 Hi, great work, i Really like the DVBViewer. A nice feature would be a possibility to ste the position for recording-info and the status-line. I use DVD-Viewer on a "real TV-Set" in overscanmode, so i can see only some pixels of the Channel-Info, the recording-Info and the status-line. EBG is fine, but thes infos are at the top or the bottom of the page, so not everything con be seen. Is there a chance to see that feature? Kind regards: Thilo Quote Link to comment
Guest Oliver Posted May 2, 2004 Share Posted May 2, 2004 Add this section to the setup.ini of the full version of the DVBViewer. With this settings you can modify some positions: [OSD]AspectX=1,1 AspectY=1,2 TeletextPosX=20 TeletextPosY=20 ChannelPosX=10 ChannelPosY=8 RecTipX=10 RecTipY=10 GaugePosX=30 GaugePosY=8 Bye PS: Maybe that works with the TE, too, but I've never tested it. Quote Link to comment
reesthil Posted June 13, 2004 Author Share Posted June 13, 2004 Hi Oliver, thanks ... sorry, I just found your answer today ;-) I have managed it to get all elements at a visible position. But I don't really understand it: ChannelPos and RecTip are x/y-positions from the upper left corner, gauge from the lower left. What ist the meaning of AspectX/Y? Do I have to use "." or "," for the floating points? I own the full-version, it's worth the 15€ ..... Thanks : Thilo Quote Link to comment
