HOWTO: Windows Powershell and DVBViewer
dbraner
Hi all,
the windows powershell is installed with Windows 7 by default. For older Windows versions it can be downloaded from Microsoft for free. To start powershell in Windows 7 simply type in "powershell" in the search field of the start menu.
Here is a short example how DVBViewer can be controlled by powershell:
$MyDVB = new-object -comobject "DVBViewerServer.DVBViewer"
$MyDVB.SendCommand(42)
The example above will start DVBViewer and activate channel 2 (actionid = 42). There should be no blank between SendCommand and "(42)". The command fails if DVBViewer is already running.
EDIT: Accessing an already running DVBViewer:
$MyDVB = [System.Runtime.InteropServices.Marshal]::GetActiveObject("DVBViewerServer.DVBViewer")
You can get a listing of all methods and properties of the $MyDVB object with the command:
$MyDVB | get-Member
For further operations see the DVBViewer COM interface documentation. It should be possible to use events too, have to test this.
Edited by dbraner
